Ken, I just noticed on the 19th Century Italian that the owner let you photograph (http://www.kensmithbasses.com/double...t_Italian.html) has the strings wound on the tuners in a normal C extension method instead of how you normally see it without an extension. Was this done because the person is normally used to a C-extension or is there some benefit to doing it this way?
Personally, I think it opens the sound up a bit as well extending the after length. The Candi Bass is now strung that way as well and sounds great. The web pics of the Candi were taken before I switched the A and E around on the pegs. My Storioni is strung that way as well. ![]() |
In their previous "normal" positions, the A string lacked power and volume while the E string had decent power but felt really tight. Now, the A string is feels much tighter and has a good deal more volume. It feels and sounds very similar to the D string now. The E feels and sounds much looser and pliant now with the longer afterlength. But the biggest benefit of the switch is that the E has a much broader and bigger bottom. Playing it open, it now sounds almost organ-like, though perhaps a bit less direct. I love the sound up close, but I don't know what it sounds like far away (which I think is more relevant to the audience). But for now, count me as a convert. I also had problems with a harsh G string, so I put a Pirastro rubber tone filter on my G string. Meh, give me a couple of days, but I think it sounded better without it. I've been told that a soundpost adjustment may be the reason the bass seems to hate G strings (I've tried a Flexocor, Original and '92, and I've tried an Obligato; they all had a twangy guitar quality to them. The current Helicore orchestral seems to work best so far). I really need to get this bass setup one of these days. |
It's not just the length change when switching, it's also the angle of pull. The A-string is now a much sharper bend and the 'E' is shallower than before. Considering the thickness of the E-string (.105 avg) combined with the normal sharp angle pull, the switching to the upper peg is a drastic change. Perhaps the 'freedom' given to the string when moving it to the A-peg reflects back in the sound and tension as well.
I moved this from the 'Candi Sale' thread over to here as it is a completely different topic discussion...
Will unwinding the E & A at the same time reduce enough pressure to let the soundpost fall, or should it be ok? I'd like to test this on my bass.
very interesting topic,
i once have seen a bass that was strung this way (see picture). now i begin to understand why |
Lie the Bass down carefully and loosen the D and G slightly as well so the Bridge doesn't try lifting. The Post is held more by the G and D than the A and E but be careful of bridge movement while doing this. In the winter, the Post is usually tighter.
Now that's drastic. The thickest string the highest and the thinnest the lowest. Looks like some re-learning is in order here as far as tuning goes. Still, I turn the wrong peg on occasion as not all of my 'E' are up high, just most of them. Also, I spent my whole life with the E being the lowest so even if all the Basses are strung the same, in a pinch I grab the wrong tuner.
Eh, this is Orlando....we don't get winters
On my bass, the A string in its "normal" position sounded pretty weak and flabby, while the E string had more bite to its sound but felt too tight. But in their current positions, (E on the A-peg, and A on the E-peg) they sound much better. The A string feels much tighter now and sounds more direct with more bite, while the E feels much looser and sounds more sonorous with a nice low end. I've mentioned all this in my post above. So basically, you can string your bass in the manner you described above; it will probably improve your sound overall. But I think the best way to decide if this is right way for you is to listen to your current setup and figure out which strings need improvement and how. I find that a shorter after-length combined with a sharper angle where the string crosses the nut leads to a brighter sound that has more bite, as well as a tighter feel to the string. A longer after-length with a gentler angle leads to a more sonorous and richer sound, as well as a looser feel. However, a longer after-length can also lead to a weaker and flabbier sound, so be cautious about that. |
(but the bass in the pic didnīt sound that good to me) |
Anselme, that's an interesting pegbox with its open back - don't see them very often. Also the spacing of the machines in two "pairs". Do you remember what bass that was? I've only see machines installed like that by another local maker. |
i have some more pics if youīre interested |
Love to see more pics!
ok matthew, here we go.
iirc the bass had on original string lenth of 98cm (38,5") the luthier changed the neck, now it has 108cm (42,5") i will not comment this, if you have your own opinion what a well proportioned bass is, well... ![]() the sound was a little to harsh and bright for my taste. iīm not sure if its a real vuillaume. although the st. ceciles were a kind of economyclass-instruments, this one seems to be too less accurate made, imho. i am courious what ken (and arnold?) will say. Last edited by Anselm Hauke; 01-29-2008 at 02:13 PM. |
three more pics
Thanks for posting those Anselme
That is one peculiar looking bass, particularly around the neck region. Kinda looks like a regular bass with a "cello" style top stuck onto it. Is all that carving (double button etc) all part of the design, or is it a result of a reconstruction somehow? From the side, the neck heel looks rather weird ... how to be sure where your D stop is with such a wide heel curvature! looking again at those machines, they can't be original? sure looks to me like the whole pegbox has been reworked in an "individual" way. mt |
