Old 02-21-2007, 11:41 AM
Lightbulb FFs, Bridge and Rib depth..
Not sure yet, I am thinking something original but Italian looking. Certainly not a copy of any of those shown.
On the Ribs, if you make them that deep, it may slow down the response and punch. My two Best Basses to date had LESS than 8" ribs. That being my Dodd at 7 1/2" and my Cornerless at 7 5/8" mainly. The taper is needed but mainly in the upper bout and at the Neck. That's the right idea. If you can, make two rib shells and fit the same Top and Back to both. Then see which sounds better.
On the FFs, make them spaced far enough at the upper eyes for the Bridge feet so that the bridge width matches the Bass size re:3/4, 7/8, 4/4, 5/4 .. etc. If spaced too close like on my Bass, you will need a 5/8 to 3/4 sized bridge for a 4/4 Bass. Mine has been damaged with the Top pushed down on the G-string side from being too wide with a 170mm wide bridge instead of a 150mm or smaller size which the FFs dictate be used in order to sit properly over the Bass bar.
