Old 06-19-2009, 05:28 PM
Default Help with my String/Bridge Height
Hi all, so I recently had my bridge re-cut since the E string side was far too low...Unfortunately, the problem has not been fixed so I decided to take measurements and see what you all think of this.
Height from belly to the top of the string at bridge:
G - 16 cm
D - 17 cm
A - 17 cm
E - 16.5 cm
Height from end of fingerboard to the very under part of the string:
G - 4 mm
D - 6.5 mm
A - 6 mm
E - 5.5 mm
From reading all the posts on this server it seems that my strings are not consistent in height at all...
I like 4mm for the G, but the 2.5 mm height increase on the D seems like too much of a gap. I also need way more than 5.5 mm on the E string, it seems that it should be at least 7 mm...
I also noticed that the strings aren't exactly IN the grooves at the bridge. The G string fits in nicely, with space due to how thin it is...But the D, A and E are somewhat over the slots.
My nut spacing between strings is perfect at 10 mm, and the height is consistent.
Also, the spacing between the strings at the bridge is consistent at 25 mm.
