Old 10-27-2009, 03:46 AM
Jonny Blomgren's Avatar
Jonny Blomgren Jonny Blomgren is offline
Jonny Blomgren is on a distinguished road
Well, if you have the right tools, and if you are confident you can do the job, then yes, it's not a difficult task. Just take your time, be careful, don't mess up the shielding and you should be good to go.
I guess I could manage then.
I'm curious. Any particular reason you would choose the 18V over the original 9V pre-amp?
I did get the impression the 9V wasn't made anymore. Otherwise than that it would be the dipswitches. I'm very happy with the sound from the bass now.
I looked over the electronics today and my problems are: oxide in the balance pot and that the plastic ring around the jack is breaking.
So maybe just a new jack would be just enough at the time beeing.
Old 10-27-2009, 06:44 AM
Lightbulb upgrade or maintenance..
Replacing the standard Jack is not uncommon. There are Cables out there that kill the jacks in time so this is normal maintenance I think.
As far as the 9v unit goes, I have them in stock for replacements and for sale as well for the aftermarket.
The D.I.P. switch is the main difference in the new Circuit. The second batter just gives it a bit more life in the end before replacing the Batteries. With the oxidation in the cavity I would suggest wiping the control cavity down and then re-shielding it. Unfortunately, we cannot sell or ship the shielding paint we use.
The DIP is preset to a slightly different setting overall than the 9v unit but the setting for the 9v are within the 4 choices for each Band of EQ and are marked on the instruction sheet. The newer 18v unit also costs a bit more than the older 9v design. Knobs and Jacks are sold separately regardless of which Circuit you buy.
