#41
I use on my fretted and fretless Smith basses, on the ebony fretboard, the "Smith classic wax polish" and the result was much better than only the lemon oil.
Best regards |
#42
Yes, the Smith Classic Wax Polish is excellent for the Ebony FB.
Tim Bishop |
#43
I didn't mention the wax polish because not everyone has it. Still, in the shop we normally use mineral oil for maintenance or the wax polish. In the finishing we do put an initial coat of oil on the board when oiling the neck and body but just that one coat and then wiped off. That is just a sealer, one time.
#44
I own and owned a lot of BTs, BMTs and BSRs and I found that the newer BSR necks feel thicker, beefier than the older BT and BMT necks. What was the reason for this change ? Customer demand ? Construction issue ? Ken's personal feel ?
It's not about pro and con of the neck thickness in common. I feel comfortable with both. I'm only interested in the reason for the change at Smith basses. I would also like to know when exactly the transition to the beefier necks has started. |
#45
The rear of the necks are more consistent now as well to ensure that the area under the truss rod entrance and nut is not weak in case of a fall. Thin necks or overly thick ones can promote bad technique in ones playing. Many people are self taught and may not know the difference but comfort is the goal here. Straining your hand, wrist or fingers for over or undersized necks can promote injury as well over long periods of time. |
| Currently Active Users Viewing This Thread: 157 (0 members and 157 guests) | |
