Old 03-03-2011, 12:44 PM
Originally Posted by Ruben E garcia View Post
Sure Mat but he also said to make a very small path with a 90 degrees angle... I know u rather do a big one about 10d, and that's ok, but it makes me wonder if what he do could apply to a db top also
Please explain what this means, and who "he" is...???
Old 03-03-2011, 02:10 PM
Sorry Mr. Schnitzer, we are talking about the Article on my post # 139, the Articule is:
A series of articles by David Harris as he observes
Luthier Jan Shelley at work…
Old 04-26-2011, 11:24 AM
Default Update
Edges Almost ready
SP patch Drying as we speak:
Old 04-26-2011, 12:51 PM
Old 04-26-2011, 05:18 PM
nice clamps Reuben. Suggest you put a bolt through the glued-up neck of the clamp, for longevity, otherwise they'll pull apart one day when you tighten up and need it most!
Old 04-27-2011, 08:09 AM
Good idea I need to make few more for the bass bar
Old 04-27-2011, 09:26 AM
Question Bassbar
Is that Bass Bar in with the grain up and down or at an angle to the grain? I can't tell from these pictures. Also, how thick is that Bar?
Old 04-27-2011, 09:53 AM
May be u can see the bass bar grain better in this picture:
The bass bar grain is parallel to the top grain,
I have to shave the hump a little to do the edges, anyways it will be replace by a new bar.
I will tell you later how tick it is
Old 04-27-2011, 10:39 AM
Default parallel?
If it was there already or an integral Bar, take it out. The new Bar needs to be at a slight angle. There is a formula for that but can't recall it also, most guys have their own way but not straight as for one, it wont do as good a job and two, straight with grain will promote cracks along the Bar.
Old 04-27-2011, 11:54 AM
Chuck have some instructions on how to position the BB (somewhat confusing instructions), I was thinking on placing the new one in the same position as the current one, of course unless this one is running 100% parallel to the top grain
Old 04-27-2011, 07:27 PM
Default The famous Sound Post Patch
Old 04-27-2011, 07:29 PM
the Bar is 1" Thick
Old 04-27-2011, 07:43 PM
Looks like a pretty good SP patch to me ... well done! I find doing a SP patch is one of the most satisfying repairs to do.
Is that a crack near the bottom end of the bass bar, running into the bass bar? If so I think that spot might be a candidate for a small inlay patch as well.
Old 04-27-2011, 10:27 PM
Thank you,
PS. its runs about an inch in the bar, yes I think I may do a inlay patch also there, can you see the crack on post #151 picture?
Old 04-27-2011, 10:57 PM
yep that's the one. But careful, you'll have much less depth to deal with, only 6-7mm. It's possibly overkill, but I'd do it.
Old 04-28-2011, 06:31 PM
Default Intregral or glue on Bass bar
I say this bar is glue on to the top , for some reason I not 100% sure
Old 04-28-2011, 07:01 PM
yes 100% sure it's glued, otherwise the grain lines would match. But note, it's a very close/almost invisible glue join ... that's what you need to achieve with your new bar!
Old 04-28-2011, 07:57 PM
Yes they did a good job on that join, fact its hard to tell other that the grain doesnt match 100%
Old 04-29-2011, 02:34 AM
On that pic you can see 100% the bas is NOT the Top but a separate Bar.
Old 04-29-2011, 03:32 PM
Correct.
So Ken To answer your previous question the bar is 1" thick
