Old 03-17-2021, 12:41 PM
Dick Jones Dick Jones is offline
Dick Jones is on a distinguished road
Default Two band eq - help!
I have an older Ken Smith 2 band eq fitted to an Overwater fretless bass. Sounds brilliant! But I need to connect the built in XLR to use with my Trace Elliot amplifier (that has an XLR input). So the information I need is:
does the built in pull active/passive pot switch the battery in and out of circuit, and, if so, can I disconnect the switched jack socket, connect the ring and sleeve wires together, then parallel the XLR with a mono jack?
Sorry to be a bit long-winded! Whoever installed the circuit made a bit of a mess and I need to tidy it up!
Cheers!
