Old 01-04-2010, 03:39 PM
dayan tejada dayan tejada is offline
dayan tejada is on a distinguished road
Question bsr6m info ?
thanks. it is posible have any info about this bass 6M143599T (serial) year , volts , wood , features all about it , will be great 4 me .
Old 01-04-2010, 03:47 PM
Default Well....
Well, from what I read from the serial number, it is a Smith 6-String Bass - "M" Series; Made in 1999; Has the 9V pre-amp; Tiger Maple Body. Ken may have to correct or provided additional information from his records.
Old 01-04-2010, 03:51 PM
Cool More Info.....
You can find out more about this model here:
http://www.kensmithbasses.com/models...ton/bsrcrm.htm
Old 01-04-2010, 04:05 PM
thanks 4 help
Old 01-04-2010, 04:13 PM
Lightbulb but...
In 1999 when your bass was made the circuit was the 9v unit. The specs page only shows the current model specs.
Old 01-04-2010, 05:31 PM
Ken , talking about sound 9v and 18v any notable diference , its posible upgrade?
Old 01-04-2010, 08:01 PM
Lightbulb yes..
1- The build structure is different.
2- The 18v model takes 2 batteries and they drain together as one.
3- The frequency settings for the boost/cut points have 4 positions INSIDE the bass that can be 'carefully' adjusted by taking the plate off. It can be broken from misuse or careless handling as well. The 9v settings are within this switch system as well. The pre-set when we install or sell the unit is set differently from the 9v 'fixed' settings.
