Old 01-29-2009, 05:56 AM
Craig you may have to wait a good 24 hours for any result from me. The top is on but I need to cut a new soundpost and get it all singing again.
OK is singing again.
yes is louder, yes is more responsive to bow (even strung with Spiros) . E string shaketh the floor. But, still very bright, and i think this is partly cos my bridge is too thin at the top.
I am happy I spent the time on regraduating the top. Worked for me.
I have ordered some Evahs for a special treat. We'll see how she go.
Old 01-30-2009, 07:58 AM
Glad to hear your bass back together and working well after re-graduating.
There is a electronics repair shop in our town that is willing to lend me an old audio oscillator, I may take them up on the offer.
Old 04-16-2009, 11:19 AM
Default Hope Springs Eternal
Today is sunny and warm, and for the first time, it feels like Spring.
Here is a photo of the bass, and for the fist time, its starting to look like a bass.
Old 04-16-2009, 07:01 PM
Nice looking bass, Craig! Now let's get some finish on 'er. This is the ultimate varnishing weather. (Today is mid 60's F., a gentle breeze, low humidity and dappled sunshine.)
Old 04-17-2009, 02:26 PM
Looking great Creag!
Do you need some tuners? PM me.
Old 04-30-2009, 08:41 AM
Here is the latest.
I have decided to set up the bass, before the finish process, to avoid scratches and dents.
Made the saddle, nut and fitted a sound post; then fit a bridge and proceeded to string it up.
Most of the nuts I have seen have wider spacing between the E and A strings and then the spacing gets smaller between the D and G string. This set up would work better on my beveled fingerboard (layout issues), but, I will try using 10 mm between every string as stated in the "Luthiers Corner".
ID:	982  Click image for larger version
Old 04-30-2009, 08:58 AM
With only one string on the bass, I could not resist plucking out the first note....
Then I let my son try it with a bow.
Old 04-30-2009, 08:59 AM
Exclamation NOT Between..
Here is the latest.
The string spacing should always be measured from center to center and never between the strings. That will space the string wider on the lowers and narrower on the uppers. With center-to-center spacing, the pencil line only being spaced, the lower strings will looks closer than the uppers but in reality, the centers in which you place your fingers will be even.
Old 04-30-2009, 09:03 AM
A boy and his bass.
Old 04-30-2009, 09:06 AM
Yes, Center to center!
Old 04-30-2009, 09:11 AM
Bass Inspection.
Old 04-30-2009, 09:18 AM
I would rather get the next three strings on the bass then sit at the computer.
Here are some progress pictures from the last 2-3 weeks. Enjoy them.
Old 04-30-2009, 09:22 AM
The $3.99 end pin reamer.
ID:	988  Click image for larger version
ID:	989  Click image for larger version
Old 04-30-2009, 09:26 AM
Neck fitting.
ID:	992  Click image for larger version
Old 04-30-2009, 09:34 AM
Neck gluing rig.
ID:	994  Click image for larger version
Old 04-30-2009, 09:39 AM
Chips from the workshop.
Old 04-30-2009, 09:41 AM
Heel shaping.
Old 04-30-2009, 09:47 AM
Carbon fiber implant.
ID:	998  Click image for larger version
ID:	999  Click image for larger version
Old 04-30-2009, 09:52 AM
Still more work to be done; back to the shop.
Old 05-07-2009, 08:47 AM
Hi Craig I only just caught this latest update!
The bass is looking great. You must feel pretty chuffed about it. Well done!
