#81
The spacing is wide and with the low string height, I can just barely clear the C-bouts on the outer strings with the Bow. If the spacing was narrower, the strings would be moved slightly inwards moving the outer string higher up on the bridge slightly for clearance as the overhang on the sides of the outer strings is playable but much less than a regular 4-string. Usually we see basses like this at 25-26mm spacing but with the wide board, why not go wider? The only improvement I could suggest is the neck being moved out to 35-40mm for the bridge to go higher off the Top to clear the Bouts better with still a low string height if desired. Still, I think I can play this bass and plan to try it at an Orchestra rehearsal or two in the least when the season starts. |
#82
I'm going to have to punt on this one. I don't play enough anymore to have had experience with all the strings that are out there now. I can say that for the low B I would tend to favor a steel rope-core because they are brighter and usually punchier. It's a bit of work to get them going because of that construction, but usually passages where you'd need a low B aren't fast. A string that is warm and mellow just gets muddy on most basses. Pizz is difficult enough without the extra damping.
#83
I have used Perm B before but I was told that the current string Thom. Precision is a good 'B' but, it's as old as the bass. I need to but a new string so it's either that 'B' which has a solid core or a Perm. One bass I tried had Flex. 92s but the 'B' was a Jaegar blue/medium and played ok mixed with the 92s. Now that I have the Perm's on the bass which play well, I need a 'B' to match. |
#84
We will have to develop a bass that is intended for fifths tuning and that is fast enough to start bringing out these kinds of passages cleanly. That will surely mean another look at what an orchestra bass is supposed to sound like, how it should be played (yeah, I know; really well). This is currently where my head is at in bass development. BTW, I saw a 5'er not along ago that had the low B string spacing very close to the E. Other strings were spaced about normally. The bridge was modified to get the B out of the way, so to speak. The player said that he needed the B from time to time, but not often enough to give it equal standing. I tried playing the bass (everyone else fled from the room), and the arrangement wasn't hard to get used to. I think somewhere in the forum someone else has already mentioned setting the bass up this way, but it was the first one I'd ever seen. That's what I like about the bass world. Just when you think you've seen it all, you haven't. ![]() |
#85
On the spacing and crowning for the B at the bridge, yes some bridges are cut like that for 5s but if you go and measure 100 bridges, the spacing from center to center in MMs, tell me how many are spaced evenly on even a 4 string. Most basses are not spaced perfectly, even to the eye. I can see the point of doing this to a B making it closer but it might be hard to jump down and not over reach for the B being closer not to mention hitting the C Bout with the bow hairs or the corner with the Frog. What Beeth. meant to be played and what is required now is way way different. 3 or maybe 4 gut strings with high action playing the sextuplets in the 9th? lol.. in your dreams. That last page was like a pink slip. I think that's why those parts say Cello-Bass, same part. LOL.. Means "Lots Of Luck!" ... lol.. (the other meaning!) |
#86
Anybody ever try (on a 5 stringer) a high C string and a C extension?
#88
Okay, I'm listening.
#89
My quest if ONLY for a Low 'B' to match the Permanent set at the moment,
#90
I think the Perm B would be a good solution. I really like the low C, so I don't see why it would be much different. You could also go with a spirocore, but it will sound better if it's old. FWIW, Brian |
#91
If you've got the spare scratch, I'm sure a Genssler (sp?) string would be the best. aside from that, I think most 5ers I've heard of have a spiro low B because it's reliably loud and articulate.
#92
I have a Spiro solo Extension E/C on the my Claudot and the other 3 strings are Original Flexocors. It sounds good but not a perfect match. It does work however. |
#93
Never saw anything like it. I have seen 5-stringers with a high C and a low E, and with a low B and a high G. It would be interesting to see (and hear) a 5-er with a C-extension on the low E. But, I think that would be quite a cumbersome rig to handle.
#94
I had a chance yesterday to briefly play Joe Guastefeste's Busan which is set up with five strings. The fingerboard is extended width over the neck on the B side and the bridge takes a dive from the E to B string putting the B somewhat out of the way. Beautiful bass.
#95
I like the Thomastic Superflexible B. It has bite, but it's not as bright as the Spiro.
#96
![]() Oh, and I ordered the B yesterday with some other stock I needed. ![]() Should be here today. ![]() |
#97
Not sure I understand your question, Ken, but I used the Superflexible B with a full set of BelCantos. It sounded well-matched.
#98
Nice BUT, the strings on the Bass are Permanents and that's what I need to match up. I have the Perm B now but haven't had time to put it on yet.
#99
I put the Perm B on shortly after my last post but. Then I re-cut the top of the bridge to clear the C-bouts better. Now, the bass plays tight but is playable and the Perm B works just find. I have one concert under my belt so far and a few more to play the 5er on before the season ends.
#100
>>>>> The bass was sold about a year after it was modified. All is good here.
