Old 04-23-2011, 08:56 AM
Eric, nice work, i understand your joy.
but please take care if you climb on the chair with the rolls.
Old 04-23-2011, 09:49 AM
Eric Swanson's Avatar
Eric, is that a new frog? If not, wow!
Right?
Amazingly, that is the original frog, rebuilt, re-machined (with a custom milling machine tool, made for the frog), with new wood only added as needed. The "chevals" added to replace damaged ebony (as I have learned they are called), are essentially undetectable, even under close scrutiny. Naturally, there is the faintest shift in grain direction. The glue lines themselves are completely invisible. I am attaching some closeups.
He made a new button, underslide, inlays, and French Eyes. I am including a shot of the mangled originals, which he returned to me. The milling cutter for remachining the frog is in the photo's upper right corner.
He upgraded the mountings from the original nickel to silver. He also picked some really stunning inlay material; which is a touch more dramatic than the originals, which were blandly figured.
Apparently, he routinely makes new frogs for people who use older bows, so that the bow can be in action without the frog being at risk.
He offered me the option of rebuilding or making a matching frog. I took him up on his offer to rebuild. It is nothing short of amazing, from a couple of inches away.
Here's an article he wrote, with photos, on replacing a broken tongue:
http://www.wepapers.com/Papers/11054...iolin_Bow_Frog
He also filled the stick and removed all traces of the accident. Before this work, it looked as if an enthusiastic dog had been allowed to chew on it for an hour or so. Let's just say that having the stick run over by countless automobiles and trucks, on a paved street, did it no good...miraculously, the stick itself was not broken. Perhaps the bow case helped a tiny bit, before the bow was actually out of the case, lying on the asphalt...
Name:	original metal parts.jpg
ID:	2064  Click image for larger version
Name:	restored frog tool and parts.JPG
ID:	2065  Click image for larger version
Name:	frog closeup.jpg
ID:	2066  Click image for larger version
Name:	frog closeup, stamp side.jpg
Old 04-23-2011, 09:53 AM
Ah, you caught me! Thanks for the warning; I will heed it.
Old 04-23-2011, 10:50 AM
i was just thinking at the threadtitle ;-)
thanks for the many detailed pics, very interesting
Old 04-23-2011, 03:38 PM
Default More photos...
It seems even more impressive to me, mechanically speaking, when I see the process...
Name:	frog, machined for new tongue.jpg
ID:	2068  Click image for larger version
Name:	frog machining process.jpg
ID:	2069  Click image for larger version
Name:	machined frog, hair view.jpg
ID:	2072  Click image for larger version
Name:	machined frog, slide view.jpg
ID:	2073  Click image for larger version
Name:	new tongue glued in, side.jpg
Name:	new tongue.jpg
Old 11-04-2013, 06:41 AM
Default This bow at VSA conference
Jerry Pasewicz is planning to use this bow as a sample in his upcoming talk at the VSA conference.
Looks like it'll be on Saturday, Novemember 9th, directly after Arnold Schnitzer's, Jay VanDe Kopple's, and David Gage's talk on bass wolfs:
3:00 – 4:00 Pm: "Taming the Bass Wolf"
Dulaney Valley Ballroom
Speakers: Jay Vande Kopple, Arnold Schnitzer, David Gage
4:00 – 5:00 Pm: "Bow maintenance and restoration"
Speaker: Jerry Pasewicz
I wish that I could hear both talks...
The bass wolf talk looks very interesting, as well.
All I can say is, bless Mr. Pasewicz's patience, dedication, and skill!
Old 11-24-2013, 08:00 PM
Only update is that Jerry Pasewicz added a bullfrog leather thumb grip, after he brought the bow back to the show and did some maintenance on it.
The bullfrog is tougher, according to Jerry. It has a textured surface, too, which I am enjoining. He made a good thing better...
