Old 02-17-2011, 08:47 PM
Thumbs up yes..
Originally Posted by Eduardo Barbosa View Post
I hope this is relevant,
In my experience the height of the nut dramatically changed the feel of my basses.
I have it as low as I possibly can with no buzzes.
I re-cut almost every Nut if too high to as low as possible. The danger here is changing string gauges. If using a larger diameter gauge and you need it low and then go to a thinner gauge after lowering the Nut, then you might get buzzes. The fixes depending on the exact problem or degree of it is to either slightly shim the Nut or, shave the fingerboard back from the half position to the Nut or from somewhere in-between.
The music we play is hard enough. Why fight the bass more than you have to?
