Old 09-11-2012, 10:37 AM
Originally Posted by Dave Whitla View Post
Following on from that, does actual tension (as measured on scale in lbs or kg) translate directly to the string feeling tight or loose, or is that feeling more abstract, like the relationship between balance and weight of bows?
I have played several basses with the same strings on them. They all feel different. So, I think the bass has more to do with the tension than the string specs in that regard.
Tailpiece angle, after length, string length, bridge height, nut height, fingerboard camber, neck strength, etc., all have something to do with the tension of your bass. I never go by numbers published on string tension other than maybe one compared to another. Once on a bass, then you can see how it feels. Belcantos on my Marconcini feel different than on my Bollbach Lion or Halle Tarr or any other bass. Same strings, different basses, different tensions!
