#27
I visited Biasie in NYC yesterday to inspect the progress and go over the final measurements of the Neck and String Length alterations. The Neck Graft for the Scroll is well under way and he even put some matching Varnish on the Maple Cheeks I had added. It looks like it belongs now so I was happy about that.
I looks as if we will not be doing any cutting to the Top or Back around the Block other than converting the Dovetail joint to a Mortise and deepening it. Some of the Top was cut under the Fingerboard area to accommodate the deeper Neck-set which before hand just sat on top of the Block and not in it. The FFs are extremely wide and the old Bassbar we left in was set in a bit from the upper Eye rather than up against it. This Bass can actually take a 3/4 sized 150mm Bridge and sit mostly over the entire 'bar. If we use a 165mm Bridge like the one used before on the Bass is will sit slightly over the center of the 'bar. I would prefer the wider Bridge being that the Bass is so wide. If the 'bar was out further towards the edge of the upper F-eye, it would need something closer to a 180mm Bridge blank. I expect to have this Bass in my hands to play and break-in over the summer. Somewhere along the way I will decide if I want a C-Extension on it. If it's a Bass I am going to use myself in the Orchestra then I will have the Ext. put on. The Graft is set so that the outer Scroll edge is even with the plane of the Neck under the Fingerboard joint which seems just right for the Extension to be fit around the Scroll. After 4 years we now believe this Bass to be English and no longer a big Mystery with the exception of the actual maker and date. Because of this I have changed the name from 'Mystery Bass' to 'Olde English'. I have also altered the Webpage quite a bit on this as well as deleting all the question and answer stuff with the various 'blind' opinions given from around the world. This Thread as well as the original TB Thread says it all so the original information and search is not lost. Here is the link to the updated 'Olde English' page.
| Currently Active Users Viewing This Thread: 11 (0 members and 11 guests) | |
