  #22
Old 08-25-2009, 03:48 PM
Originally Posted by Don Edge View Post
I did call them and have been to their store. They were more but did not talk about a package deal.
Sound I like/looking for in relation to drums and me: I like punchy full bass with a good bottom. The Fender rumble does have a decent sound. Don't get me wrong. It just sounds somewhat muddy in the low registers and has to be turned up to get the punchy full good bottom bass sound. I do not play the bass by turning up the rig or bass and barely touching the strings. I am farely rough. This may have been a problem with some of the lesser quality 10 or 12 inch speakers. The sound tends to come out exploding thus popping the inferior speaker causing me to go with the 15s. With the Eden set-up, I may have to change, somewhat, how I play. This would not be an issue if I could get the same sound I am looking for at lower volumes but with good quality.
Does this make sense?
Well, the 15' (depending on maker and design of cab) is designed to hit the lower range (30 - 2k Hz) and hopefully somewhere in the 103 SPL range. The 10's and 12's you reference: Sounds like you either pushed them beyond what they were rated or maybe you were overdriving the amp with your bass. Several possibilities here.
There are endless possibilities as to getting you where you need to be, soundwise. I would encourage you to pursue a better bass rig/amp set-up vs. what you have. In the end, you have to be satisfied with your set-up and sound, outside of all the varying and subjective advice you may receive; including mine. All I can do is answer your questions and offer advice based on my experience.
