Old 11-10-2009, 09:35 AM
Wink 4 and 8 ohm/WT-550?
Originally Posted by Mendell Beckford View Post
Mr Tim, I have a question for you. What happens if you pair a 4ohm and an 8ohm speaker together driven by the Eden 550?....
Not a problem. The WT-550 can handle a 2 ohm load. A 4 ohm cabinet + an 8 ohm cabinet, in parallel, will create a 2.667 load. So, you are good to go!
BTW - You could actually add one more 8 ohm cabinet to the above scenario; if you need it. That would put you at the 2 ohm load mark, which the WT-550 can handle.
Enjoy!
