Old 11-30-2009, 10:03 PM
Two totally unrelated thoughts:
1) When a bass gets major restoration to every single component the bass you bring home is not the bass you started out with. Is somebody going to guaranty that back if they don't remove it, yank the braces, re-join the back plates, and replace the braces (with nice new ones)? Won't those bass-side cracks get fixed better if you remove and re-make the bass-bar? The neck is already out; it's a pure accident if it doesn't need a change of angle, right? How tight will the sides be if you don't address the popsicle-stick braces? New board, saddle, tailpiece, nut . . . How "french" will it be after that? Maybe that doesn't matter. Maybe it shouldn't.
2) Am I wrong that when you do that much work, it's gonna need to settle and you'll probably need to open it up again in a few years anyway?
