Old 12-18-2009, 07:22 PM
Question Well.....
Originally Posted by Tom Albano View Post
Hey Tim, The clack starts at the first fret and is fairly consistent all the way down to around the 12 or 15th fret... The strings are at a reasonable height the bass is not set super low (non taper). Maybe I can try fooling with the saddle height but I dont want the "A" to feel "out of place" to my fingers on the fretboard. Anyway Ill have it looked at next time Im ready to change strings Ill just pay for a real deal setup I guess and see what if anything can be done.
Any other opinions? Im listening ....
Did you have this problem prior to this? "Reasonable height" relative to the radius of the fretboard is the question in my mind.
You could also check the relief in your neck. Although, you did state you put heavier gauge strings on it: This would add a little more tension to the neck. At any rate, check the neck, do you have some or any relief? Or, is it flat or maybe even convex shaped? If you think the neck needs adjustment, it doesn't take much: Very slight adjustments. The necks on these basses are VERY stable. If you think the neck looks right, then I would say adjust your A-string saddle (Note: adjust each side of saddle evenly!) with slight adjustments and see if that helps you.
