Old 03-14-2007, 03:20 PM
Lightbulb Couldn't wait?
I never understood why people like single cut designs. I think they would be clunky, heavy, and unnecessarily impede my ability to play in the upper registers.
Wood covered pickups look ok, but I just don't see the need. I'm not sure if it would interfere with the magnetic field around the pickups or not. If it does it's dead out of the gates for me. At no point do I ever want to sacrifice anything in tone for pure looks. If it has no effect then I don't see a real problem with them other than maybe durability.
Can't wait to see Ken's responses.
Ok, here I am. We made Wooden cases for the PUs in the beginning (1979-1983) BUT, moved away from that. The reason is that it moves the magnetic field further from the strings and you loose volume. If made thin, the top of the cover might break or split.. Been there, done that.. no thank you.. have moved on.. NEXT!!
Single Cut? WHY? Structurally, I think it's a 'stupid' idea. With all the concern about even neck Bow and adjustability you are going to LOCK it down on the low sting side while the treble strings pull and twist it from the other side? Is this to create tension in the neck to produce sounds the builder couldn't get by just making a good structural sonic Bass?
I don't know who's idea this was actually but one time when I was fishing on a boat and all the other boats rushed to this splash in the water a few hundred yards away I asked my older friend, "Should we go over there and fish?" His reply was (in a wisdomish way) "One fool draws many!"
If someone can't make a Bass with good neck structure, stability and tonal response, try this? Not in my book!
