Make a trip to Pa and see me. You will return a different person in half a days visit. |
Hey Ken, thanks for the taking the time to reply. Sorry for the inconvenience about this issue but it seems to be a bit of a learning curve for me.
So, are you saying that in half position if I press down on the E string, that the under part of the string should have the same string height (distance between board to under part of string) all the way up the board? Ie. Once the string is pressed down in half position, the note a or b etc on the same string should almost be flat to the board? On my bass there are several mm's in string height between the note A while the string is pressed in half pos. |
Thanks again to Ken for all the helpful information. It seems that this bass needs to have the fingerboard plained and re-profiled. It's a wonderful sounding instrument, it really anchors the section but the fingerboard is a bit off in design.
I've had to raise the adjusters up to 9mm on each side just so the G string gets 5mm of string height. It's a bit strange...The G and D string has virtually no "scoop" (perhaps the incorrect term), it's very flat... G (5mm), D (6mm)...But then the A is (10 mm) and E (11mm). So, there is a massive dip between the D and A strings. This means that the E and A strings are under a heck of a lot more tension than the D and G. That's why the bass feels so tight on the bottom two strings. Basically, I need the G string side of the fingerboard to be lower (rounded), or perhaps the fingerboard has warped or sunken on the bass side. Last edited by Calvin Marks; 01-27-2010 at 09:52 AM. |
