There were other kinds of carving machines back then. The integral bar wood left in was not so neatly carved. The graduations often way over normal specs. Basses like the ones labeled Morelli and Pfretzschner made nearly 100 years ago had Top and Back plates carved by a machine of some sort. Back around 1978 I took the top off an old German or Tirol style Bass. I spent no less than 8 full hours carving that out and replacing it with a real Bar. I was a busy working musician then in the NY studios and in my down time, I fiddled with basses, inside and out. That was my only Bassbar job and the chalk fit was as good as the eye could see. Carving by machine and leaving a chunk of wood in there doesn't take 8 hours! I think on the Museum 'Quality' Basses, that phrase to me doesn't mean it's IN a Museum. Most basses in Museums would need a full restoration and modernization with the proper fittings to go back in to service. I own and have owned many basses in this class. I have seen them worked on and modified to all degrees you can imagine. In every single case, the bass met the modern needs and to do what it was intended to do, be played! Basses fall apart in Museums. The more they are left alone, the more it will take to fix them. Putting in a REAL Bar if it doesn't have one even IF to be put back in its cage will help it live better and longer under string tension. Just my opinion and experience talking here. I would also like to mention than in that period that was the only bass that needed a Bar. I would have done more if needed. I did many top cracks, cross bars and a few plates on and off. Maybe 20-30 basses passed thru me then or so, I can't remember. It was a part time hobby and no one complained about my work back then either. I had one main bass for 15 years and it only needed strings on occassion. I glued one corner on it and put some glue in a rib crack opening in the 15 years besides bridge set-up work. I did only the jobs that the basses needed that I bought and sold then. |
