Hard to get a smooth bowing sound from unless you have the right bass and technique combined. So, hard to bow. I disagree, sorry.
But the Weichs are easy enough to bow. Which was where I started. I've just changed my strings around again lately. I settled on BCs because they are easier for quick bowing, but it was a close contest with the Weichs. As we say back home:
We're a' Jock Tamson's bairns! |
Not a Hybrid string if you want a plain jazz string. The sound is deep and shorter on the pizz with a true fundamental in tone. For a bowing hybrid string, the Spiro weichs work well for some basses. Still, they might be a bot bright or thin sounding as compared to an orchestra bass with orchestra strings. Guys n Gals, I want to point out that I am judging this from playing mainly older Orchestra grade basses. Some not as old but still, finer instruments in price and tone than any ply, hybrid or modern factory bass in general. If the bass you have is in that range then my findings might be different than yours. You must judge for yourself what works for your bass, your ears and your playing. |
Questions for the more experienced arco players:
I know spiros will stand out in an orchestra but what about for solo or maybe auditions, would spirocore weich be a good choice? Second question: Does the compromises that have to be made to be a good hybrid string prevent it from excelling at both arco and pizz? Or is it possible for a string to be excellant for both (not just adequate) jazz and orchestra? |
Number two is a tough question Euddie.
I must be honest and say that I have not found the answer. I accept that we are all different. We all see beauty in different things. Nothing stays the same. Could a perfect string actually exist? Maybe it is our quest as musicians to take something that isn't perfect and to make it work on our terms? |
| Currently Active Users Viewing This Thread: 12 (0 members and 12 guests) | |
