I have an old Englehardt with an 'ebonized' maple board.
I all but have it sold to a friend except for one area on the G that buzzez. So I proceded to replane the board (several areas had worn through the thick lacquer and I thought that might be adding to the cause). as it stands now, the board is true and I've added a tiny bit of relief but no matter what I do, I still get (string/fingerboard) buzzing at the same spot. but only on the G and only in this same spot? I'm not sure if its because this is at the 'bottom' of the relief arching or ?? |
Thanks Wayne,
I thought it might be a sympathetic buzz on the top side of the string but eliminated that (I think) as I can't affect it in any way by using 'support' fingering above the note or not....no difference - if that makes sense. also, to the "no matter what I do"; I had the same thoughts... its starting to remind me of working on my old vw years ago. trying to get out a ''flat spot" in the carb...after a half dozen corrections had no effect, I figured out it was something else completely different. But there are aurguably less variables on an upright! but still I did wonder if maybe it was a flat spot in the string or something....but nothings visible? maybe inside the core? |
when I talked about trueing the board, I was referring to making sure the relief or scoop in the board in constant rather than wavy, uneven, or had low or high spots.
It sounds as though the fingerboard just isn't shaped right. Since it is maple (and probably way to thin anyway) I wouldn't waste time making it thinner still - a new, properly shaped ebony fingerboard will make a big difference in the sound and playability of the bass.
yes, I basically started from zero again and made sure that the relief arc in the board was a fair curve with no bumps or pits, by block sanding with a small enough block, then using a block file.
this seemed to work well. |
