Old 02-03-2011, 02:15 AM
We opted for no direct box as it would make the box bigger and more expensive. If we did, it would be a bigger, upgraded more expensive unit. Everything we did was top notch so it's not cheap. Most people that want a preamp do not need the direct out. I can usually do that from the Amp as it takes the signal you feed it.
I agree that adding a DI would make it bigger and more expensive, though I'm not opposed to paying well for the perfect tool for a given task (the reason I have those old Neumann and RCA microphones in the studio...). Is this a preamp that you sell direct, or would a KSB dealer stock such an item?
