Does anyone have info on the best adjusters and where to get them?
I think that is a subjective question. Lets here from Jeff and Arnold on this one who each may not agree on what they personally like just to see how favorites vary regardless of results.
Boys?? I have adjusters from Arnold and Jeff and they all work as well as the walnut handle ones from Shen which I personally like the most. Shen sells them if you are interested but you may need to go thru a dealer like Arnold or Jeff. Those require two different sized holes upper and lower. The ones they like do not. |
Arnold and I usually use custom one piece aluminum adjusters with some slight variations of style. But I think we both would agree that the adjusters that Lemur sells are extremely fine quality and are probably the best available to the average person. These were designed by Bob Stenholm who also made some impressive low C machines.
Last edited by Jeff Bollbach; 01-23-2007 at 02:39 PM. Reason: none of yer beeswax |
I've seen bridge adjusters mounted such that the strings could be adjusted individually...above the heart (?) of the bridge rather than above the feet.
Have any of you tried bridges with these adjusters? What do you think and feel about them?
"The future? Why, the future is NOW!", said the mirror. |
I assume you mean MPM bridges.When I first saw them I thought they would never work. Having been to Mike Pecanic's place and seen one of these guys I changed my mind. They are well made and work. I can't comment on the tone or longevity though as I just haven't seen enough of them.
Thanks Jeff for the advice - just wondering though which Lemur ones you refer to to buy as they have several listed?
I think I'm going to get one and have a setup done with it in the near future.
The ones listed as ebony. They have 3 sizes available-all are the same top quality.
Jeff? Arnold? |
Actually, I'm gonna drop the MPM appellation and just use "Pecanic" for my stuff, that should cut down on the confusion.
Would a person who installs your accessories be correctly referred to as a "PecanicMechanic"?
Hello, Mike Pecanic. When I measure my bridge, the outside of the legs are spread ~ 6 in. apart, and the top of the bridge reaches ~ 6 1/2 in. high from the top table. On my bass, the table arch is more pronounced than was on my Strunal and so it's probably about 7 in. high from the bottom feet to the top of the bridge.
With your bridges, are you talking about how far the feet are spread apart from the outside, the inside, or is it a different dimension? http://www.mikepecanic.com/content.php?id=bass_bridges
Hey Ken, is this ok?
Hi Johnny, Actually I need ALL of the dimensions, the inside spread, the outside spread of the feet, as well as the current string height of each string off the table. Then we can talk about what you are wanting the bridge to do, up and down, just down, just up, etc. Arnold, you're partially right as in 49 states Pecanic rhymes with mechanic. In Arizona the proper pronouciation is more like "peck-a-nick", and in Croatia it's pronounced "pech-e-nich" while in Bulgaria I think the pronounciation sounds more like "crap-4-brains"...never much liked them anyway... |
I play in open position while standing and so the bridge will be angled up...no one should get hurt. ![]()
(BTW, Mr Moser is from Austria, not from Germany. However, they speak German there, too.) |
i have mr. mosers adjusters on two of my basses. one with included full-circle pickup.
i like them. i met mr. moser at last musikmesse in frankfurt. he´s a nice guy. (i met jonas there too, also nice guy )EDIT: i added an animated gif of a moseradjuster, hope i works... EDIT2: it works if you click it. its a ball-joint, so you can adjust a different height on each bridge-leg EDIT3: http://www.moser-klangwerkstatt.com/ Last edited by Anselm Hauke; 06-13-2007 at 10:20 AM. |
That thing looks like it's dancing.
