#81
Agreed. This particular cabinet does have a tweeter and L-Pad Attenuator. So, he should be able to dial-in some nice crisp/sparkly highs. With the 2x10 Eminence Speakers and a well designed cabinet, he should be good to go (53Hz-17kHz). If it meets his coverage needs.
Tim Bishop |
#83
Currently living in Panama Central America and don't have the large music stores to be able to test out so really hoping you guys could lead me in the right path. Thanks guys for all your imput! |
#84
This combo would most likely serve you well then.
Tim Bishop |
#85
Thanks Tim for all of your input and advice!
I feel like am already a part of the KS family! Love the Forum! |
#86
You're welcome!
Tim Bishop |
#87
Did some research on the Ampeg PF-500 and seems that there some issues with this amp. What other amp/cab combo would you guys recommend?
#88
Eden Metro's.
http://www.eden-electronics.com/prod...m_dc210xlt.htm .... or .... http://www.eden-electronics.com/prod...v/dc112xlt.asp They have been discontinued, however, if you look on the used market and shop smart you can find one at a good price. Great combo amps and they can handle a 2 ohm load! Or... An Eden WTX-500 into an Eden 210XST 8 ohm cabinet is another option. http://www.eden-electronics.com/prod...tx/wtx500.aspx The WTX-500 can handle a 4 ohm load, so, you can add an additional Eden 210XST or 210XLT 8 ohm cabinet for additional coverage (when needed). There are many other options.
Tim Bishop |
#89
Thanks Tim your full of knowledge and am glad that you take time to give great advice! Know lets see if I can find something used.
Thanks Bud! |
#90
Tim Bishop |
#91
Just found this on Ebay but the guy will not ship only local pick up.
This would have been perfect and great price and it looks likes its in great shape. Sucks! http://www.ebay.com/itm/Eden-DC210XL...item3f2b893e10 |
#92
Tim Bishop |
#93
Hi Tim, after searching in my local stores in Panama I have not been able to find any Eden Amps unfortunately! The only thing that I have found is a SWR WorkingPro 2x10C 8 ohm Bass Combo...
Your thoughts? I can get this for $900.00 brand new. If not good then I will have to bring one from the States once I got to pick up my bass once I get the call from Ken that it's ready. Thanks in advance! |
#94
Will that amp handle a 4 ohm load? If so, how much wattage from the amp at 4 ohms? Can it handle a 2 ohm load? If so, how much wattage at 2 ohms?
Tim Bishop |
#95
After doing a little research, I don't think your getting the best bang for the buck. While these amps are no longer made, they also don't provide that much headroom: 260W at 8 ohms and 400W at 4 ohms (with an 8 ohm extension cabinet), you need to ask yourself if that's enough coverage for your needs. Way to many variables for me to assume here. For sure the price is too high for what you are getting. You should be able to get one of those on the used market for half that. I'd hold out for something better if I were you.
Tim Bishop |
#96
![]() Tim, really thank you for your guidance!!! |
#97
Tim Bishop |
#98
Hi Tim,
So after a few days searching online I have landed a New Eden WTX 264 amp and EX410 Neo cab @ 8 ohms. Price was just right with free shipping. The cab is a manufactured refurbished and I got the 2 year warranty. Hopefully I have no issues with the cab. This will be my practice amp and small gig/ church events. Let me know what u think... Thanks bud! By the way I was looking at you KS bass collection and it's very impressive! ![]() |
#99
When I play at Church and because we utilize Aviom's with in-ear monitors, all I need is a DI out of my Eden WTDI to FOH and I have all I need. Makes for a really easy set-up, without any additional work needed (i.e. like hauling a cabinet with me), and the bass in the mix is perfect. You can do the same with your WTX-264.
Tim Bishop |
#100
Thanks Tim for all the help and assistance and guiding me in the right path on getting the correct amp / cab set up! Bass is done and should be able to play it after the holidays once I go back home for a few days. Work just has me really busy traveling all over Central and South America. On positive thing about the job is that am able to afforded these new toys.
| Currently Active Users Viewing This Thread: 20 (0 members and 20 guests) | |
