Old 01-31-2021, 10:03 AM
Cool Otto Rubner, Markneukirchen c.1930 (SOLD)
After careful research, we conclude that this bass is the work of Otto Rubner c.1930 (b.1885-d.1963, son, pupil and successor to Joseph Rubner b.1864-d.1927).
Having seen several Rubner and Meyer basses pictured and some in person, the tuners in the reverse order is the first thing that came to mind for Meyer. Then the purfling around the top but not the back was another clue pointing Rubner and not Meyer. Meyer basses made later have the upper top shaped more squarely by the neck block but the earliest ones go around like the French Cello model Double Basses. In separate messages back and forth with the current Bass Master in both the Meyer and Rubner shops (Ackert), we have concluded that this IS a Rubner and not a Meyer. 'Ackert sent me pictures of two old Rubner basses he has that have the same narrow outer linings measuring only 7-8mm wide. A feature not seen on Meyer or other makers from Saxony.
About 30 years ago, this bass was restored and the back button was replaced with a graft from a neck break. The Luthier restoring the bass also over varnished the bass to the current and beautifully applied deep wine-red color. Regardless, the bass is in great shape and hasn't been opened since that restoration.
The sound is fairly deep, rich and powerful sounding. Having played beside is in the hands of the previous owner for about a decade, I can attest to its sound. When it was restored decades ago, the neck was set way too shallow (possibly the original over-stand), making it difficult to play in thumb position without some back strain.
Recent new neck grafted, Fingerboard, Bridge, End-pin unit and new chromatic C-Extension. (new pictures below)
(SOLD)
Measurements:
String Length; 41 1/2" (with new graft)
Top/Back Length; 44" top, 44 1/2" back
Upper Bout; 19 1/2"
Middle Bout; 14 1/4"
Lower Bout; 26"
Ribs; 7 3/4" (8 1/4" w/T&B), 6 1/8" at Neck (6 5/8" w/T&B)
Top; spruce
Back and Ribs; highly flamed maple.
Neck/Scroll; figured maple with neck graft
ID:	3898  Click image for larger version
ID:	3899  Click image for larger version
ID:	3900  Click image for larger version
ID:	3902  Click image for larger version
Old 01-31-2021, 10:07 AM
Lightbulb a few more details..
The outer linings are smaller the normal size usually seen on German basses, allowing the ribs to move more.
The F-holes are the earlier Rubner and A.Meyer style, both neighboring Saxon makers at the time.
The import sticker is all that is inside but there is some torn paper near it where the makers label probably once was.
Also, here's a pic from a few years ago in concert, the Rubner is the second row, outside, just behind me with my Italian..
ID:	3905  Click image for larger version
ID:	3906  Click image for larger version
ID:	3907  Click image for larger version
ID:	3911  Click image for larger version
Old 02-02-2022, 11:57 PM
Cool Nee neck graft, fb, bridge, C-Extension
After nearly 100 years, this bass finally has a proper neck set along with all the other set-up needs to modern playing. String length is now 41 1/2".
ID:	3992  Click image for larger version
Name:	Rubner back 2.jpg
ID:	3993  Click image for larger version
Name:	Rubner E side.jpg
ID:	3994  Click image for larger version
Name:	Rubner G side.jpg
ID:	3995  Click image for larger version
Name:	Rubner head E side.jpg
Name:	Rubner head G side.jpg
