  #21
Old 07-25-2007, 06:27 PM
Cool Adjustments...
Originally Posted by Amit Shtriker View Post
Haven't tried them yet, Bob I think I can't find them in my location.. But I will try them in my trip to U.S in a couple of months Do you know where can I find them? I think that the big music stores don't have them..
These are regular strings without the taper core right? I guess I'll have to set up the bass again for them
I order them direct from Ken. They aren't taper core, though I wish they would make taper core compressors. In truth I found my Smith accepted them just fine without needing any adjustments.
Amit, if you do decide to change strings from Taper Cores to something other than Taper Cores and depending on how good your set-up was, you most likely will need to complete another set-up and what a complete waste of your money that will be: Again, I would recommend you give the Taper Cores some time to adjust to your playing since you are not use to them. Otherwise, good luck!
