Old 03-15-2008, 03:36 AM
Jeff Jenkins Jeff Jenkins is offline
Jeff Jenkins is on a distinguished road
Proud new forum member. I just picked up #85205 P/J 4. It is identical to yours in the pics above. Apparently the walnut back has shrunk at some point and been repaired. I dont know who did the work, but I believe it couldve been done better.
Hey Ken, it seems the nut action is quite high. The bass plays well with the neck perfectly straight, but the distance at the nut from the bottom of the string to the top of fingerboard is considerably higher than most of my other basses. Just wondering if this is a normal way you dress your nut? Also, do you have a factory pickup height suggestion for these Smith P/J's? This is my second Smith bass. The first was a BSR6 Walnut top that I had about two years ago, it was probably an early 200? model. Liked it, but couldnt get used to the six, so I parted ways with it. I believe Im going to be very happy with this 85 Dovetail 4 P/J. BTW, Ive requested your freindship on myspace, Ken, so when you get a chance, hook me up so I can put you on my top friends with the other bass companies that I use. Thanks.
-Jeff Jenkins
