Old 05-12-2009, 07:36 PM
Default Bass Parts
Ken,
Do you sell all parts for your basses or just the ones on the web site.
Thanks
Mike
Old 05-13-2009, 12:37 AM
Question parts?
Originally Posted by Michael Wilson View Post
Ken,
Thanks
Mike
What other parts are you referring to?
Old 05-13-2009, 07:16 PM
Default Bass Parts
Input jacks.
Thanks
Mike
Old 05-13-2009, 08:12 PM
Thumbs up look closer..
Input jacks.
Thanks
Mike
http://www.kensmithbasses.com/access...s/circuits.htm
Old 05-13-2009, 09:11 PM
Jason Mendelson's Avatar
Ive had to replace the jacks on all my smiths...
gotta make sure to use the L angled 1/4" cables,
durrrrrrrrrrr
Thump_
Old 05-13-2009, 09:45 PM
Default 1/4 Jacks...
In the 10 + years I've been playing MANY Smith Basses, I've only had to replace one 1/4 jack and I mainly use the straight 1/4 cable ends (Monster Cables I might add). That was back in 1999 on my KSA 6. It was simply a bad jack that had a short; had nothing to do with the cable used. Ken sent me a new jack, I replaced it in about 2 minutes, end of story.
Old 05-13-2009, 10:39 PM
It was on my 1996 / 1997 that I purchased originally brand new... and the 1994 that I recently found at guitar center...
They werent like not working or anything,, but they would get touchy sometimes... wasnt horrible... but since 10+ years after I got the basses and I decided to get them professionally set up, I had them replaced at the same time so I dont have to worry...
Thump_
Old 05-14-2009, 03:42 PM
The jack on mine is starting to show signs of giving up when you apply pressure to the cable in a lateral direction. I've always used straight cables, but about 2 months ago swapped over to a 90 degree connector to reduce the stresses inflicted on the jack.
Old 05-14-2009, 06:59 PM
Cool I'm just extra careful.
I'm sure the 90 degree option is better for obvious reasons. I've just always been extra careful with my gear no matter what the circumstances.
Old 05-14-2009, 07:27 PM
Default Bass Part
I just need the input jack. Mine has short. Does not pay for me to ship the bass to PA at the cost of $100 bucks for shipping just for the jack.
Mike
Old 05-15-2009, 08:19 PM
Default jacks & cables
Hello all,
I replaced the jack on my circa 2000 BSR5MW (I'm the second owner) soon after purchase. The word on the street is that Monster Cables have a habit of ruining the OEM jacks and I can't say if this happened or not but the jack began to show signs on impending failure.
The jack was a bit costly at $25 plus another $10 for shipping. Spendy? Yes, but necessary. No issues, at all, since a very easy install. I am careful when plugging the same cable (90 degree) and if it takes a dump again? I'll just order another and combine that with a string order, too.
Regards, Kirk
Old 05-15-2009, 09:11 PM
Cool Monster cables
Originally Posted by Kirk P Brosius View Post
Hello all,
Regards, Kirk
Monster cables, huh? Wow, this is interesting as I've also heard the complaints about Monster Cables used in the Smith Input Jack's and why they are a supposedly a "problem". However, for me: I use Monster Cables and have for years and have never had an issue. The barrel jack's Ken uses are built well IMO.
It would be interesting to know how many Monster Cables used (in the pool of bad press) were straight vs. angled when these jacks failed. I can't help but think the answer would be 'straight' and the cause of the jack failure was due to the straight 1/4 plug taking too many good hits while plugged into the jack.
Old 05-15-2009, 09:23 PM
Thumbs up Yep.
Regards, Kirk
Yep, that's the way to go Kirk.
Old 05-15-2009, 11:48 PM
Robert Kramer's Avatar
Robert Kramer Robert Kramer is offline
Robert Kramer is on a distinguished road
I use Monster Cable without issue. I think its more of a dimensional issue. the inside diameter (I.D.) of the jack and the outside diameter(O.D.) of the plug are too close in tolerance. Used carefully, no trouble but when the union is stressed that's where the problems occur.
Old 05-15-2009, 11:58 PM
Default Yep...
Yep; exactly.
Old 05-16-2009, 10:26 AM
Default Input Jack
Monster Cable has always been a problem with my Smith basses, not sure why but every Smith bass i have owned [10] has had a problem at some point with that cable. I think i will just go ahead and send it to ken and let him do a full blown work up while he has it. Get what i pay for
Mike
Old 05-16-2009, 12:00 PM
Cool Monster..
Mike
There is nothing I can do to fix the Monster Cable problem. By their own admission, they use what they call a type '2' plug. That seems to be the problem. Any normal cable is fine in my opinion. The Monster is only good when the jack is worn and needs a tighter fit. Using this cable early on will strip the inner spring of the barrel jack.
Remedy! But several extra Jacks from us and use any super duper claimed cable you like. It wont make you play better but you might feel good spending a lot of money on a cable with tons of advertising.
I have never used Monster other than once at a trade show and then they gave me a bunch for free for all the 100s of Jacks they killed. Still, I don't use one. I will use anything but a Monster unless it's all that's available. I take 2 cables with me and neither is a Monster.
Old 05-19-2009, 07:55 PM
Cool Fortunate ?
I guess Robert and I are the fortunate few . Works for me .
Old 05-19-2009, 07:59 PM
Talking Monster Cable
Bravo Ken!!!
That cable is and always will be a input Killer!! i though it was the input jacks that were bad, but low and behold it was the monster. NEVER AGAIN in my Smith basses. Ken thanks for the new input jack, sooooooooooo easy to install, works great.
Mike
Old 05-19-2009, 08:02 PM
Default Monster?
So, Ken, is it fair to assume you don't like Monster cables, lol, .
