This is my main bass . It is a 7/8 size with a 42,5 scale . There are so many opinions on her origin that for all I know she may be from another world
![]() Any info etc would be really appreciated ![]() Last edited by Adrian Levi; 08-28-2009 at 12:41 PM. Reason: forgot to attach pics |
Two questions I have for you to start.
1, do you now if that is the original varnish? It looks kind of chippy and not French at all. 2, if you take one gear off each side, can you tell if these gears are original to that scroll or do you see some signs that something else might have been there before? 3, one more for the woofer... Is the varnish 100% the same on the Scroll as the back and ribs as far as you can tell? If it was all stripped and re-varnished, you still ight be able to tell under UV light. If this is a French bass then I would assume something along the lines of the early 20th century after WWI and a lower grade import (export model from France) by maybe the J.T.Lamy firm. Just like the commercial German factories making export grade products, France did the same thing but on a smaller scale from what I have seen but they DID do it for sure. |
1) It looks like it has been re-varnished at some stage 2) the gears are original to the scroll / there is not a hint of any other covered up holes marks etc ! 3) The neck does have a darker varnish than on the body / I am 100% sure that the bass has been repaired along the way ... I noted that the tuners are of a similar type to a Tyrollean bass I saw on the site ? |
If the Neck Varnish is different then either they did not re-finish the Neck, the neck was re-varnished during a repair in a different color OR, The Neck does NOT belong to that Bass. |
OK - I'll contact the previous owner and try to track down more info , I think that she may be helpful in that regard .Thanks so far .....
Hi Ken thanks for the replies so far ...
I talked to the previous owner and the guy who 're-finished & repaired' the bass and from from all I learned I think that the instrument is stock. Apparently the aforementioned repair man has varnished this bass on more one occasion!!!! |
