Old 01-11-2010, 07:02 PM
Default Is it only me...
... or are the output jacks on Smith basses getting worn out remarkably fast?
The two new I have (-01/-03) tend to be quite loose already.
Have you noticed that too or am I abusive to my Smith basses only?
Haven't experienced such tendency with other brands I've owned.
Old 01-11-2010, 08:31 PM
Question Jacks?
What cables are you using?
Old 01-12-2010, 04:01 AM
Different ones but the one I use most is the one a use when I practice and that one's labled X-lines.
Old 01-12-2010, 04:21 AM
Question Hmmm......
Not familiar with those cables. Out of all the Smiths I've played over the last 12 years, I've only had one output-jack fail. That was a good 8 years ago.
Do you use a straight 1/4 or angled plug-end going in to your bass?
Old 01-12-2010, 11:53 AM
Straight...
Old 01-12-2010, 12:06 PM
Lightbulb Straight.....
Straight...
Is it possible, given the straight 1/4 plug-end, that your output-jack is taking some hits while plugged in? Given the placement of the output-jack on the bass, you really need to be extra careful when using the straight 1/4 plugs into the output-jack. With the angled plug-end you reduce the impact to the output-jack in the event you sit the bass down while plugged in or whatever other impact may occur to that area of the bass while plugged in. Make sense?
Old 01-12-2010, 01:32 PM
Lightbulb Jack spring
All Jacks have an inner spring to hold the Plug. Top mount Jacks can be squeezed back as needed but barrel Jacks like these cannot. Some Cables on the Market with slightly over-sized tips or plugs can, will and do prematurely strip the strength of these springs. The Jacks/Cables that have been reported to have 'killed' the most Jacks in the last 20 years are those made by Monster. They are aware of this and use a type 2 on the cables that kill them. The regular sized type 1 is not as damaging. Jacks lasting 10 years or so are evident by this. Jacks lasting weeks or months tell a different story.
Old 01-12-2010, 03:22 PM
I've always used straight plugs and I'm not any more abusive to my Smith then any other of my basses.
It makes total sense what you're saying and I have thought about getting angeled plugs but haven't had this problem before so just haven't.
Old 01-12-2010, 03:23 PM
So you think i might have been using over sized plugs that can hade led do this?
Old 01-12-2010, 04:20 PM
Cool plugs..
Not you, the cable maker. The difference can be .002" difference.
Old 01-12-2010, 05:08 PM
Cool Well.....
I've always used straight plugs and I'm not any more abusive to my Smith then any other of my basses...
It doesn't have to be "abuse". It only takes stepping on the cord while pulling away at an angle that can apply additional stress to the output-jack.
Old 01-12-2010, 05:14 PM
Default Well......
The problem may be determining what "type" you have (oversized or not).
Old 01-12-2010, 05:16 PM
Lightbulb Others.....
I've heard others here on the Forum recommending George L's as a solution to this issue.
Old 01-12-2010, 05:22 PM
Default Plug-ends....
....It makes total sense what you're saying and I have thought about getting angeled plugs but haven't had this problem before so just haven't.
I'm only suggesting angled plugs as a possible solution and to illustrate how the angled plug could mitigate damaging these output-jacks. I also use straight 1/4's but again, I am very careful and over-aware of my surroundings and that potential "hit" that might occur to the plug at the output-jack. I'll even go as far as to unplug the cable from my bass until I am ready to play. Plus, this also helps extend battery life. : )
Old 01-12-2010, 06:10 PM
Yes, but I don't step any more on the cord while palying a Smith then any other basses.
Old 01-12-2010, 06:12 PM
Ofcourse. So I would need to find another over sized cable or just change the jack.
Old 01-12-2010, 06:15 PM
Sounds alot like me. I'm very careful too.
Just wanted to hear if any body else also have noticed this compared to other brands but it seems like my basses has been exposed to something any how. Not just the jack that tends to wear out fast.
Old 01-12-2010, 06:48 PM
Question Hmm.....
....seems like my basses has been exposed to something any how....
Well, if you bought them used, no tellin what type of history is behind them. Is it possible the issues you have were inherited?
Old 01-12-2010, 06:49 PM
Question What else?
....Just wanted to hear if any body else also have noticed this compared to other brands but it seems like my basses has been exposed to something any how. Not just the jack that tends to wear out fast.
What else has "worn out"???
Old 01-12-2010, 06:51 PM
Lightbulb No.......
No, not "over-sized" cable, but one that fits that barrel-jack better for you. Have you tried the George L's?
