Old 01-20-2007, 09:40 AM
Lightbulb Pfretzschner & Morelli
A few years ago I took in trade a large 7/8ths Bass with a Morelli Label. I had seen at least one other Morelli back in the '70s but it was a completely different Bass. Soon after acquiring this Bass I started my study on them and found quite a few identical Basses labeled G.A. Pfretzschner. I also found a few others that were labeled Morelli as well. In searching my violin makers books I would learn that G.A. Pfretzschner and all the other Pfretzschners were Bow makers exclusively but with one exception. There were 3 generations of C.F. Pfretzschners recorded in the books from the late 18th century and into the early 20th century as well. They are known as C.F. I, II and III. I believe that the shop of C.F. III made many instruments for export into USA to distributors and at least two labels were used. Andreas Morelli and G.A. Pfretzschner.
I have also seen two other Morelli type Basses that I know for a fact were made by either Karl Herrmann being the better quality Morelli Basses and Saumer Morelli being the last shop to produce them in Germany for the US market.
Here's the webpage on my fully restored Morelli which has come and gone. By the way, this was a machined carved Bass with an integral Bass Bar. When the restoration was completed, it sounded like an Italian Bass. Arnold noted how good the wood was that was used in the Bass so re-graduation was possible due to the over thick Top and Back.
http://www.kensmithbasses.com/double...lli/index.html
For other Shop type Basses, read about Juzek/Wilfer here..
Old 07-08-2009, 09:53 AM
Default Morelli Bass 1910
Hi Ken,
Here are some photos of my Morelli bass. I paid $300.00 for this about 20 years ago. It was in very rough shape and someone had refinished it. Originally, it was a golden color. I know this because the old varnish was visible under the original tuning machine half-plates. Eventually, I replaced the half plate machines with some very old ones I found at a local guitar shop. They look 'Frenchy' to me but am not sure of their origins. They were attached to a very old scroll and neck which I gave to Paul Strelau and he put the scroll on a big five string bass he and Jesse made.
A few years ago, the Morelli bass was damaged and the scroll at the neck joint was broken. My repair person felt that the only way to guarantee the work was to replace the entire neck and scroll. I still have the old scroll.
The bass has both a stamp and a label. The label is dated 1910.
http://www.flickr.com/photos/4019654...7621000224037/
Old 07-08-2009, 12:41 PM
Thumbs up ok..
The Gears are very nice old German work, not French but French style. The Bass is a bit Wilfer-like but looks like it could be Herrmann as well who made Basses for the US importer that Labeled it here in USA. They bought basses and later labeled them in USA. I have seen a few like this but not many. The date was added by the distributor as well. The same one that sold and labeled all of the Pfretschner basses. Some of them got Morelli labels as well. I have seen identical basses with either label.
On your bass, the whole neck/Scroll thing it fine being it is in the German-shop class and not handmade pedigree class. It would cost a bit more to have done the graft and repair. The finish looks fine as well. Probably as good or better than the original and old enough now not to matter,
You have two nice basses there. I spoke with Paul just a few minutes ago as well on some other unrelated business.
Old 07-09-2009, 01:05 AM
Default Blockless?
Hi Ken,
Were Morelli basses a 'blockless' bass that I've seen you write about?
It seems that this bass has blocks in the all the corners but I'm not sure what a blockless bass is.
Old 07-09-2009, 01:33 AM
Lightbulb no, and I will explain..
Hi Ken,
The Blockless Basses were mostly made in the south of Germany or in the Tirol between Italy and Germany which would be Austria or maybe even in Fussen. I do not really know for sure. Mittenwald may be involved as well. This is what I have been told. Some of them have been attributed to Bohemia but that doesn't make sense to me.
By the term 'Blockless' they mean in the Neck only. The Neck extends into the Body like an upside down heel that is like a boot aka boot neck. The 'boot' is glued to the back and top holding the two together. The Ribs 'tuck' into the Neck as well being that there is no neck block to glue them to.
These basses are hard to keep in tune as the plates move and take the neck with it every which way. They also fall apart easier and in 100 years, they look 150-200 years old after repairs. Like with most things, they were made in various qualities. The raised upper ribs going into the neck is a sign that the bass was most likely blockless if not still that way unless altered and improved.
Besides the link I provided, do a search for 'blockless' on the forum here and see what you find.
On the Morelli basses from the north, one thing to note is that many of these 'shop' basses were made without real bassbars. A section of wood is left in the top and shaped like a bassbar but it is just mass. It does not slightly oppose the grain like a real supportive bar should. Also, when these basses get repaired for the first time the lump they call a bar is shaved down to top and a new/real bar fitted. The problem at this point is the springing of the bar. This in itself can cause the top to collapse at either or both ends. The 'improved' bar can turn out to be a death sentence for the bass. In other words, unless it can be improved and done correctly, leave well enough alone until it can be done correctly. What is correct is not something that is agreed with by all as far as a bar and spring goes.
For this, read Jeff Bollbach's rant on Bassbars. This guy tells the plain painful truth. I like him for that.
Old 07-09-2009, 09:17 AM
I saw an old Sears catalog from around 1900. In it many musical instruments were sold, including several "blockless wonder" basses in standard and deluxe models. I believe they sold for $25 and $35 plus shipping...
I wonder if someone more internet-savvy can find these ads?
Old 07-09-2009, 10:08 AM
Wink lol
No, BUT I have an old Dealers catalog with these as well as the importer of the Morelli and Pfretschner lines. Also, the French Lamy basses. The 4-string models are $6. more if ordered than the standard 3-string.
How much was a Hamburger then?
Old 07-09-2009, 01:20 PM
...an old Dealers catalog ...
it´s off topic here, but regarding old catalogs:
here http://www.luthiers-mirecourt.com/do...lioth%C3%A8que
you can find MANY scans of old french instrument catalogs, scroll down and click...
for example: thibouville catalog from 1901, page 63: 3-, 4 and 5string basses, 130 -770 francs
http://www.luthiers-mirecourt.com/thibouville1901_1.htm
Old 07-09-2009, 02:54 PM
Default Calogues
Ken,
Are the photos/(drawings) or other descriptions of Morelli basses in your catalogue?
Old 07-09-2009, 03:08 PM
Cool no..
Ken,
No, juts a dealers ad for instruments by various shops. Mainly for Violins but all string instruments were imported by the same firm. They can put any label in any instrument. Like a Juzek, it's just a label. With Morelli, there never was any such person born. With Juzek there was but he didn't make any of the basses or much else for that matter. His Brother Robert ran the NY import company and used John's name on the lables they put in. With Pfretzschner, there were several bow and instrument makers with this last name but the G.A. Pf.. is fiction. There was a commercial shop/factory known as A.G. Pf. but who knew, who cared? People were and still are taught to believe and eat the Bullxxxx that the dealers feed you or the ads you/we read. It is also known as .. 'Marketing' ..!
Basses 'SOLD' with Morelli labels or brands can be wither Violin/roundback, Gamba/roundback or possibly Gamba/flatback but those were usually sold as G.A. Pfretschner's.
The Morelli labled stuff was supposed to be the higher quality of the line according the the dealers ad.
Old 07-04-2020, 10:39 PM
Peter Weil Peter Weil is offline
Peter Weil is on a distinguished road
Default Pfretzschner/Morelli 1924 (it's big!)
I was intrigued by Ken Smith's mentioning of a Morelli he had restored. The pics are no longer on this site, but I found them on the way back machine. I've got a 7/8 Pfretzschner/Morelli with a big, beautiful sound -- I got it at Chuck Traeger's shop way back when I was too young and naive to know what I was doing (except I knew it sounded great). Ken's (former) bass and mine are very similar. The dimensions are virtually identical (string length is nearly 44 inches, upper bout width about 20.8, etc.); the only clear difference I can see is that mine doesn't have the ebony at either side of the neck heel. Mine has a stamp "G. A. Pfretschner, Markneukirchen", a label that reads "Andreas Morelli, 1924", and what's presumably a repair label that says "Andre Fantoni, 27 West 46th Street, New York 36, N.Y." I've been playing jazz on this instrument as a weekend warrior type, but it's kind of a beast to play. I love the sound, but now I'm looking to get something smaller and more playable. I'm not sure what I'll do with this one.
Old 07-04-2020, 11:04 PM
http://www.kensmithbasses.com/double...lli/index.html (link corrected, post restoration)
Hi, 3 things here to mention.
1, the Ebony up at the neck heel 'platform' is from the restoration where I had the block cut down to shorten the string length. The neck was long and an, 'Eb' neck. To graft in a new shorter 'D' neck, that would have raised the cost a few thousand $$ so we left it as-is. Arnold Schnitzer did the restoration.
2, Your bass has the stamp inside as well as the Morelli label. The labels were put in here when the bass was sold from the importer but the stamp I am not sure where it was branded, USA or Germany. Both names are Fictitious. Usually, only the Violin cornered basses were branded and/or labeled Morelli, not the Gamba models. Your bass has both names inside which clearly connects the Importer as selling both name. Very interesting.
2, I knew Fantoni very well. I met him when I was in HS and hung out in both his 42nd st. shops, 27 and 37 where Paul Biase took over the business. In a way, Fantoni was a mentor to me so I enjoy hearing his name mentioned.
Old 07-05-2020, 01:16 AM
Thanks for filling in those details, Ken. I considered getting a shorter neck, too, but decided that it's not worth the trouble (and the $$). Yes, an Eb neck is what mine is, too. I realize all of the stamps and labeling contain fictitious information (except maybe the year?). That's why I like reading what people like you have to say about them. I kick myself for not asking Traeger about the previous owner(s). I suppose it's a good bet it was used in an orchestral situation, but that's just a guess. If it was a jazz bassist, he would have had a helluva time walking at bebop-type tempos unless he was a monster himself. ;-)
As an aside, Arnold was my first (electric) bass teacher when I was in high school. So it's cool to read about the great luthier work he does.
