Go Back   Ken's Corner (Bass Forums Sponsored By KSB) > Electric Basses > KSD - Ken Smith Design
Old 03-14-2007, 08:32 AM
Edwin Movintoch Edwin Movintoch is offline
Edwin Movintoch is on a distinguished road
Send a message via MSN to Edwin Movintoch
Default Pick Up Change 705
I would like change my 705 Pick ups
Any suggestion?
What s the defference in sound between a Seymour and a Bartolini
I heard that the bartos make no more "clacking" noise when slapping on the B string. Correct??
Thanks
Old 03-16-2007, 01:37 AM
Cool On what?
Any suggestion?
Thanks
Change your 705 P/U's on what model bass?
Old 03-26-2007, 04:26 PM
Ksd 705
Old 03-26-2007, 05:14 PM
Cool Why?
Ksd 705
Why would you want to change out the stock P/U's?
Old 03-27-2007, 04:33 PM
When slapping the Bstring, i have a nasty "plop"
And Ive heard thet the reason is the "bad" PU
And the "output"level is a little bit low
Thx
Old 03-27-2007, 04:42 PM
Cool Hmmmm...
Thx
Not necessarily. I'm not buying that it is a bad P/U.
Here's a couple possibilities why you may have this issue:
1. Maybe it is related to your technique
- Where on the bass are you slapping the strings and how aggressive are you when slapping?
2. Maybe the P/U's are adjusted to close to the strings.
- Depending on what you discover from 1 above, maybe you need to adjust the P/U's accordingly.
3. Depending on what you discover from 1 and 2 above, maybe you need to adjust your output gain (if applicable) on your bass to better match that to your amp.
Consider the above before you throw your money away!
