Old 01-14-2012, 11:20 AM
Frank Rubio Frank Rubio is offline
Frank Rubio is on a distinguished road
Default Neck Relief
I have a 1990 Burner Custom 5 and would like to know about adjusting the neck. Is this a two way truss rod? If not will turning to the right increase
the relief.
Old 01-14-2012, 11:48 AM
Lightbulb Truss Rod Adj.
the relief.
Hey Frank. Turning clockwise will decrease relief. Turning counter-clockwise will increase relief. NOTE: Make your adjustments in small increments (i.e. 1/4 turn's). If the neck/truss rod has not been abused and your frets are in good shape, you should be able to set your action low without fret-buzz (of course this depends on your playing style).
Old 01-14-2012, 11:54 AM
Question Question
the relief.
How would you describe your action as it is now (before any adjustments)?
Old 01-14-2012, 01:25 PM
Ronen Tat's Avatar
Adjusting the truss rod is for neck relief, not action. Once you have the right amount of relief the action is set at the bridge and nut. My point is, when adjusting the truss rod pay attention only to the neck, not the action. Take care of that later - at the bridge.
Of course, I could be wrong
Old 01-14-2012, 01:58 PM
Lightbulb Not exactly.
Who said it was for adjusting "action"? Adjusting the neck is not only for adjusting relief, but an integral part of what contributes to the action when the overall set-up has been completed.
Old 01-14-2012, 02:14 PM
Ronen Tat's Avatar
Well, adjusting the neck IS indeed only for adjusting relief AND an integral part of what contributes to the action when the overall set-up has been completed.
Old 01-15-2012, 10:45 AM
Default Neck relief
Thanks as I was tring to get a little more relief and now that i know it is counter clock wise I am glad I waited to find out. Neck relief is the first step in setting up a neck, without correct relief you have a hard time setting up the actiion.
Old 08-07-2012, 07:16 PM
What is the exact dimension of the wrench needed to adjust the trussrod ?
Old 08-07-2012, 08:42 PM
Wink Truss Rod Wrench?
Truss Rod Wrench: 1/8"
Old 08-07-2012, 10:00 PM
Exclamation
Do NOT use a 3mm wrench for the truss rod or you will strip the nut.
Old 08-08-2012, 05:02 PM
thanks all,
I was clearly aware to not use a metric system wrench.
Got to fetch a 1/8" hex wrench now
But i think that the former owner have already done bad
Old 08-10-2012, 03:44 PM
danilo ninkovic danilo ninkovic is offline
danilo ninkovic is on a distinguished road
It seems to me, neck setup somehow affect the sound of strings, not only to playbility?
Old 08-12-2012, 08:36 AM
It can, but in a subtle way. When the tension is changed on the neck from adjustment of the truss rod interacting with the string tension, it can slightly alter the resonant frequency. On a well made multi-piece neck, like Ken's, where the resonance or dead notes are not an issue, it won't be noticable, but on less expensive one piece necks that tend to have a dead note somewhere, like the 8th fret of the G string, juggling string tension and truss rod tension can sometimes bring a little life back to the dead note.
Old 10-07-2012, 03:39 PM
Another Wrench question : I need to adjsust the string height ...
Can U provide me the exact dimension of the wrench to order it
Thanx in advance
Old 10-07-2012, 04:06 PM
Thanx in advance
Smith Basses bridge saddles wrench: .05"
Old 10-07-2012, 06:24 PM
Cool wrench..
the relief.
Ok, Burners use a 4mm wrench. My comments were referring to Smith USA basses, not the old Burners. Sorry.
Turning towards the E/B takes out the relief. Turning towards the G loosens rod and increases the possibility of relief.
Old 10-09-2012, 10:35 AM
Joshua Phelps's Avatar
Default neck relief
I agree with tim here on the Neck Adjustment. Imo the Secret to a great setup & low action is a neck thats flat as possible & very level frets. Best setup i have ever Seen on a Bass Period (if you like very low action) was on a smith with a CRAZY flat neck. You Could Barely Slide a business card between the strings & the fret @ the 7th fret when fretting the 1st & 24th fret & unfretted the action was as low as i have ever seen on a bass. This Bass can Be Plucked pretty hard on all notes with 0% fret buzzing.
Think about it. Fingerboard wood is cut flat. Wouldnt it be Better for the wood also to not be bending foward? also wouldnt it make it easier to fret notes between the 3 & 12th fret without having to press the strings down another fraction of a mm due to alot of foward bow? Flat neck (flat as possible without fret buzz) is better for the wood & better for the Playability
