Old 06-08-2012, 04:19 AM
Default G string
Hi all,
I've got a minor problem on my BT4.
I strung it with a new set of DR MarcusMiller strings 45-105 and when i'm poping or playing the G string too hard, it went out of the saddle groove as if the groove was not deep enough to keep the string in place ...
Is there something to do ? surgery ? or just change to exposed core strings ?
Old 06-08-2012, 03:05 PM
Exclamation
Originally Posted by Franck Callebert View Post
Hi all,
I strung it with a new set of xx xxxx xxxxxx strings 45-105 (not Smith) and when i'm poping or playing the G string too hard, it went out of the saddle groove as if the groove was not deep enough to keep the string in place ...
Ok, try the Smith strings and the bass if not altered since we set-up and cut that Nut should work.
Old 06-08-2012, 05:32 PM
Yep Got to find this in France...
But in a taper core strings set, does every string is tapered or only the biggest ones (E, A ?)
If yes, it could solve my problem, if not, the outer diameter of the G string would be roughly the same and the problem will remain ...
Old 06-08-2012, 05:55 PM
G and D are not tapered. The G has only one winding so nothing there to taper. The D is thin and the sound almost the same with or without taper if made with 2 windings so, we no longer taper the Ds.
You can groove the saddle deeper and raise it up as well. Do carefully as once cut, it is as it is.
