Old 03-25-2013, 11:28 PM
Default I think I need a new cab
I don't think my cab can handle the lows on my BSR6EG Cocobolo/Walnut. I mean, those lows are just SO powerful and round. Thunderous isn't the word, it is the perfect B string. I was playing and I was playing on my B string and I heard the cab almost just give out. I wasn't even playing loud, its just so powerful. I wish they still made the Bergantino HT322.
Des
Old 06-10-2013, 11:38 PM
Nick Foster's Avatar
I've played through many different amps and cabs and usually if your cab is getting ready to blow when you hit a string, then you either have a shitty cab or a shitty amp or both. Always check the wattage and impedance of amps and cabs because a mismatch will lead to bad ****. Also, it's never a good idea to run an amp through a cab at max power.
http://www.divinity.ca
