Old 07-09-2013, 10:00 PM
Default pickup height
Does it matter how high the pickups are, as regards as closeness to the strings?
Des
Old 07-09-2013, 11:58 PM
Exclamation
Yes, very much so. If too close, the sound will ge muffled as the magnets pull the oscillating string when you play. The way it was set when the bass was shipped was the optimum height. Now too high and not too low. Lower will be a less metallic sound, slightly.
Old 08-23-2013, 12:06 AM
Does it matter with the wood combinations? Because of my three basses, all three have different pickup heights, as well as string heights.
Des
Old 08-23-2013, 12:44 AM
String heights are relative to pickup heights. You can be further away from the strings with the pickups without problems but too close, and you can get magnetic pull which will muffle the sound.
Neck/rod position and adjustments also play a role here.
First, I set the neck where I want it and then the bridge. I will go back to the neck adjustment if needed as well as the bridge and tweak the two till satisfied. Then, the last thing I do is set the pickups to match 'that' set-up. Different basses have different tensions for multiple reasons so even if the strings are at the same height, the pickups might be a hair closer or further. I put them down low enough 'not' to be in the way of the 'sonic oscillation' of the amplified string (I think I just invented a phrase!).
Old 08-23-2013, 01:07 AM
All my basses are made by you. I think I've been playing my 5TN for so long that I just became one with the setup and feel of that bass. The 5EG, still doesn't feel natural to me yet.
Des
Old 08-23-2013, 03:15 AM
The EG is a lacquer finish and the wood vibrates differently than the oil finished TN. Also, the woods are different as well and that also makes them vibrate differently. Vibration is also part of 'feel' so two different basses with other common construction between them but they are not identical.
Old 12-30-2013, 12:24 AM
I think I have to bring my basses in.
Des
Old 12-30-2013, 02:25 AM
Just call me when you are ready.
