Old 10-25-2013, 03:19 AM
Ronen Tat's Avatar
Question Roland GK-3B midi pickup on a Ken Smith
Anyone knows if would fit on a Smith bass - is there enough space between the bridge and pickup, and enough room for the rest of the unit to be attached?
Thanks.
Old 01-08-2014, 02:09 AM
Ronen Tat's Avatar
No Roland midi system users here?
Old 01-12-2014, 02:05 AM
Ronen Tat's Avatar
OK, I'm not giving up.
I've noticed the pickup position on wide (19mm) models is difference than your standard bass. There's more space between the bridge and b/pickup. A midi pickup would fit easily.
Is this only reserved for the wide version or also available on a standard 18mm bass?
A 19mm Ken Smith:
My Ken Smith bass:
Old 01-12-2014, 03:16 AM
Exclamation
We can move them but the poles might not line up as well.
Old 01-12-2014, 12:10 PM
Ronen Tat's Avatar
I understand. Good to know it is an option though. Thanks!
Old 01-12-2014, 03:06 PM
Maybe, but the Poles for the wide model were made for the position they are in.
Old 01-12-2014, 03:33 PM
Ronen Tat's Avatar
So, in theory, to "modify" a 18mm bass (pickup placement) you'll need a tighter pole-spacing pickups - to keep everything aligned correctly.
Old 01-12-2014, 11:37 PM
We have what we have. I have to measure a bass and see how much room we have to keep it within the poles.
Old 01-16-2014, 02:22 PM
Default GK Pickup
For Regular 18mm string spacing. If you move bridge, it is possible to put. No need to do it for 19mm.
Sleek Elite
Old 01-16-2014, 02:38 PM
Ronen Tat's Avatar
Move the bridge? No way
But I understand that with the 19mm model this is not an issue.
Old 03-07-2014, 12:00 AM
I am considering putting a MIDI pickup on my 6EG.
Des
