Old 11-28-2016, 03:00 PM
Default Unknown bass id
Hi everybody,
Found this bass and I have never seen one like this.
Can you help on identify this bass?
I'll ask for more pics from the seller.
Regards,
Pedro
ID:	3430  Click image for larger version
ID:	3431  Click image for larger version
ID:	3433  Click image for larger version
ID:	3434  Click image for larger version
Old 11-28-2016, 04:10 PM
Exclamation
Possibly a Blockelss German/Austrian bass. The back of the head maybe done after, Maybe. Probably within the 100 year old range.
Could also be a Spanish bass as the Pegbox looks like it was done by a Guitar maker.
The Neck is Worm eaten as well. The Back is very thin also. This will be an expensive bass to restore. Top off, new Neck block, New Neck/Graft? If you keep that Head which is weak with the open back. And what ever work the Top and Back needs as well once opened up.
Keep the pictures and look for a better, more healthy bass. This Bass more then likely will cost more to restore than its final value when all done.
Old 11-28-2016, 04:18 PM
Thanks for the fast answer
I was expecting that issues
Thanks
Old 11-28-2016, 05:09 PM
Thanks
ok, all set.
