Old 10-29-2018, 08:57 PM
Default 95 BMT Fusion 5 string.
Hello, I was hoping to find out some info on my 5 string BMT which is a masterpiece BTW! just outstanding.
Can I ask why you do not make the NT's this way anymore?
as well the neck profile on this bass is very slim, seems even slimmer than other Smith 5's I have played, has there been much variation in the neck profile's since the 90's?
also
Why were only a small number of these basses made, was this a special run?
Also, just to mention I also have a BT4 from 1985 which is my number #1
I hope to get that refurb'd someday by the factory.
Best
- Tom
ID:	3648  Click image for larger version
Old 10-29-2018, 09:37 PM
Several reasons to answer your question but mainly, we re-designed the basses in the latter 90s to be like the earlier 80s basses. So, the BMTs were a limited period bass model for a few reasons as well as that style of building.
Old 10-30-2018, 04:44 PM
Hi
Thanks for getting back to me.
I just noticed the tip top of the truss nut is rounded but further in still has teeth to grip. If I wanted to change the nut can this be screwed off the rod? It looks like It can be. As well what size truss nut would I order as a replacement?
Thanks
T
We have only one size Nut since the beginning. Do NOT use 3mm to adjust it. That will round it. Use only 1/8th inch. Which will come with the New Nut when you order. For any and all business., Email me at support@kensmithbasses.com.
