I've been curious about the priorities and methods of general bass set up.
As a relatively inexperienced player, compared to others here, I have a lot to learn, but I've played a lot of different basses, both at jazz jam sessions, and shops catering to primarily classical players or jazz players. At a recent jam session I had the unexpected opportunity to play a few tunes on a Prescott bass that cost upwards of $25K. The strings were hiked up higher than any bass I've ever played; so much that it was painful after just a few minutes. It did put out some sound though, but if you can't play what's in your head, what's the point. I'll be going back for more this weekend.![]() At the other extreme are basses with fb's nearly straight and strings almost touching the board. These are the easiest to play, but you give up some volume. I'm somewhere in the later camp for sure. At the risk of opening a can of worms, I wonder if we could benefit from a discussion: How to set up a bass for various styles of play. What are the considerations for planing a fb, cutting a bridge etc. How do they differ for pizz and arco play. I understand that the there isn't a Jazz setup or a Classical setup, but rather a combination of elements that accomodate a particular players style and wishes. Thoughts anyone? |
I gave a few answers in another Thread here and suggested to Greg to start this new Set-up Thread. I would like to post my previous replies and thoughts to start and get this ball rolling.
All the guys I have used for repairs and set-ups in the past do work for all types of players. I have seen quite a varied preference of height, width and arch from both Orchestral and Jazz players. I will venture to say that there is no such thing as a Jazz or Classical set-up at all but rather just preferred set-up Specs depending on the actual Player. Set-up starts with the Bass itself and the Fingerboard radius you have. If you like a certain arch and the Fingerboard is over or under rounded for the way you like it, the Bridge arch will not give the desired height from string to string across the FB. In this case, it needs to be re-worked or replaced. If the Neck is set too low to the Top, it may be difficult to get the strings low enough. Re-setting the Neck stand is a common Professional modification that improves the possibility of getting the desired set-up. As each Bass is different, it is important to have the Bass in its best possible condition before the set-up begins. If not, the work will be a compromise for a less that optimum set-up. |
There are many set-up variations for both classical and jazz players. To generalize, classical players need more arch in the fingerboard, which helps with clean arco string crossings. Most jazz players like the board a little flatter in the arch, which makes it easier to cross strings pizzicato. When strings are set high, and the bass is to be bowed, a lot of fingerboard and bridge arch is required, and the strings may need to be spaced farther apart. That's because when you press an individual string to the fingerboard you move it down a lot compared to its adjacent strings. This makes bowing cleanly on one string very difficult. As far as camber (longitudinal scoop), gut strings need more. Players who pluck hard generally need more. Players who fire the strings downward (plucking finger toward the bass' belly) need more. A flattish arch is good for finesse players and easy-going bowers, also classical soloists. These are all generalizations; every player needs something a little bit different.
While there may be no "official" designation of jazz or classical setups, IMO, they certainly do exist as de facto standards. The great majority of my doublebass setups are for jazz players and while there are certainly exceptions, the great majority of jazz players who come to me want setups where the strings are as close as possible to the fingerboard, without any buzzing while pulling the strings as hard as they would ever pull them. This usually means a fairly flat arch and strings fairly close together. For most classical players, this would be the last thing in the world they would want for playing arco.
One of the first questions I ask a new customer is whether they want their bass setup for jazz or classical. Even if jazz or classical setups do not exist, the customers always seem to know what I am talking about. |
When I bought my Upton, I told them I wanted it set up for jazz play with the strings close to the fingerboard. I wasn't experienced' enough to give any more information regarding string spacing or radius. The bass arrived almost exactly the way I expected although I might prefer less scoop in the fb and I did cut the nut slots a bit deeper. My teacher commented on the nice setup. Since his main bass was set up by Bob, I take it as a compliment.
Aside from the sheer size of his bass, it's got an incredible setup and tone. Question, Why do basses vary so much regarding tension? Is it the tailpiece , the thickness of the top? What is it? |
I would think that assuming the neck is set correctly, a properly planed fingerboard would be the first step. No? |
I got this on Bass from the UK and it looked like it was adjusted for King Kong. The dealer said it was a standard London Orchestra set-up. I have to have the FB re-cambered, cut a new nut 1mm closer spaced per string, lower the strings and re-cut the bridge arch as well as move them closer 1mm just to play it and not be in pain. That to me a a bit more than just a set-up but more common than you would think when Basses change hands. Just my opinion here. Neck sets are often not optimum for playing from what I have seen. Ask Arnold and Jeff how often they re-set a Neck and the percentage of Basses that can and have benefited from this whether it was actually done or not. |
I agree Arnold and Bob BUT, my point is that after the FB is done, the Bass can still be set-up 6 ways from Sunday! I have changed the set-up on several of my Basses as far as height and spacing without needing the already worked FB re-done. Just because some people need more or less camber than others it doesn't mean the FB 'always' has to be done over. Can we agree on this gentleman? and Arnold? (lol goes there..lol)Talk about dissin the host.. geesszzz.. ![]() |
I think the main point Bob was making, to which I applauded, was this: very often, the fingerboard is a mess, and no amount of adjusting to the bridge, nut, post, or camshaft will make that bass play well. No disrespect meant, Ken.
Camshaft? Wrong forum?
WTFIT![]() |
Again, my point in set-up is set-up and not repair. I agree that the FB must be right to do the best set-up but if the FB is ok and you make all the other adjustments needed for the player or desired style of playing, isn't that setting up the Bass as well? Bob? Arnold? Jeff? Lets make a menu of all the points concerning the set-up, shall we? Also, what if the FB is thin and re-cambering will not be as effective on a thin board as it would be on a new thicker board. Would putting a new board on the Bass be part of set-up? Would a new Bridge be part of set-up? |
Again, where is the camshaft on a bass?
As the saying goes, "if you have to ask, you can't afford it"...
2) Nut 3) Bridge 4) Soundpost 5) Tailpiece 6) Strings Have I missed anything, fellas? |
[quote=Arnold Schnitzer;466]
![]() And, what if the Neck is too thick and needs to be carved down for the player or the Neck is too weak and needs Graphite reinforcement rods and then a new FB. Would the Neck in itself be part of the set-up if it needs to be worked on? Or, how about the Neck stand or pitch. If the Neck set causes the Bridge to be low or it is hard to Bow a 5 1/2" tall bridge with 1/2" string height and not hit the C-bouts, is correcting the Neck stand/Pitch/Bridge height factor part of the set-up or a Repair in itself? So, where do we draw the line here between Set-up and Repair or alteration? That, is the question! Or, is Set-up in itself actually a Repair that doesn't require the Top to come off or a crack patched from the outside? |
The 6 items Arnold mentioned (Fingerboard, Nut, Bridge, Soundpost, Tailpiece, & Strings) covers what I consider to be normal setup work. IMO, the neck work that Ken mentioned is repair work that would be done prior to or in addition to normal setup work.
