Old 02-01-2007, 05:01 PM
Set-up starts with the Bass itself and the Fingerboard radius you have. If you like a certain arch and the Fingerboard is over or under rounded for the way you like it, the Bridge arch will not give the desired height from string to string across the FB.
You're not saying that a player should make the best of a fingerboard radius or scoop that doesn't quite fit their preference are you?
I would think that assuming the neck is set correctly, a properly planed fingerboard would be the first step. No?
