![]() I have seen just about everything from a Broom Stick in the Endpin to Carbon Fiber rods and Bent Endpins as well as the other standard variety from Steel Rods to Aluminum or Ebony Shafts. Some people think the material makes a difference in sound and some also think the length extended outwards or left inside un-extended also affects the tone and volume of the Bass.
I also want to point out that sound may differ as well regardless of the Endpin type or extension depending on the surface you are playing on. Do any of you notice that with Amps some sound better on wheels and some on the rubber depending on the floor type and the room? What are your thoughts and experiences on this? |
![]() For several years I've been using the carbon fiber Laborie endpin. A couple months ago I got the new design of this endpin which is made of an African hardwood (padauk). Laborie told me he had been surprised at how much better the hardwood endpin sounded than the carbon fiber. I was pretty skeptical but there really is a noticable difference. The sound is warmer and more resonant with the wooden endpin. Its prettier too.
![]() Several months ago, I stuck a 5/8" birch dowel in place of the hollow metal pin and the bass sounded much warmer and seemed to have a bit more volume. This was on both tile and hardwood floors. The problem is that I sit on a low stool and with the bass laying into me, it slid on the crutch tip. It just didn't seem worth the trouble.
Regarding amps, I've used a small tripod Ultimate stand to help me hear, but nothing else. |
![]() This question of endpins has been rather interesting to me lately, as we tried changing a friend of mines from something that was about 2-3 feet long to a 8 inch carbon fiber endpin. With nothing else changed his sound was much warmer and less metallic. Not sure if it has more to do with the material or the length, but it was a huge difference and I am now going to experiment around a bit. (since I don't really use much of an endpin this is easier then for some.)
I wonder though on those that use wood endpins. Do you have a metal tip to keep it in place or some sort of rubber cap on the end ? |
![]() Quote:
I am wondering why they can't use the regular Endpin socket rather than drilling a second hole in the Block for the tilted unit. Also, how is it different to use a bent Endpin or just tilt the Bass with a regular Endpin. The entire Philly Orch and NY Phil in the sections use regular Endpins. I think I did see Hal Robinson do a solo one day and have a bent Endpin on that Bass but not on any of the Orchestral Basses I have seen. |
![]() The Laborie endpin has a soft rubber ball on the end which grips very well. Its not prone to slippage anyway since the endpin comes out of the bass at an angle, so is pretty much perpendicular to the floor when you're playing.
![]() Quote:
No doubt those of us using this type of endpin are a small minority, but we're a growing one! I bet you will see more and more players everywhere (including in major sections) using this type in the future. |
![]() I have seen Viennese type Basses with a separate wood socket for the Tailwire close to the Top and the Endpin by the center. I haven't seen any vintage Basses of high value thus far with a second hole drilled towards the Back of the Bass for this bent thing. I would be worried about weakening the Bass at the block area myself.
I myself do a combination of sitting or standing depending on how I feel or what Bass I am using. Some Endpins have a round Rubber Ball at the end but on a wooden floor, they tend to slide a bit more than on carpet. One one of my Basses in Restoration now I was trying to decide which Endpin type to use since I will only be up a few inches if that much. I was considering either a standard 3/8 steel pin unit or a wooden one and maybe make a few sizes for standing or sitting lengths if it mattered at all sound wise. I usually cut off most of the excess inside the Bass on both the Steel and Carbon Fiber Rods. The Bass is a 7/8-4/4 size standing about 6ft5in (77") from the top saddle to the tip of the Scroll. After the Bass is shortened at the Block and Neck Graft is will be about 75" minimum. With the Endpin in all the way, you can add about 3 1/2" with the Endpin all the way in. This is one Bass I actually measured for an Endpin unit so that when I sit, the Back doesn't touch the floor. The Socket is about 1/2" or so forward of center so this was a concern as the Ribs are 8.5" inside the plates (over 9" with Top & Back). Tilting this Bass when I sit is of some concern since the 'Pin will be very low. |
![]() I only use about 6" of my endpin, with approx 3" sticking out of the bass. What effect, if any, would removing the excess have on the sound?
![]() Quote:
![]() Also, Glen Moore uses the Laborie pin in his big old bass, I believe it's a Klotz.
![]() Quote:
I also used a 45º bent pin in my normal socket for a while. It changed the balance of the bass a bit, causing it to fall in towards my body at a more open angle, but didn't have the dramatic effect of the Laborie pin with the drilled hole. Some years ago I was doing a recording session, jazz quartet, and the engineer just couldn't come up with a good bass sound, he must have spent an hour at this. He had me set up in a carpeted booth. I finally took the bass out of the room, played a few notes on a hardwood floor, and that was it. From that point on, I always ask for a piece of plywood to set the bass on if there is carpeting. The carpet seemed to suck up the percussive attack of the instrument. Hard surfaces seem to emphasize it, what I want in jazz playing, at least. Last edited by Eric Hochberg; 07-30-2007 at 04:21 PM. |
![]() One thing I forgot to mention is that when I tried the experiment with my friend's bass we tried the same thing with mine. For my bass it did not make as dramatic of a difference as his. Might of had to do with mine being shorter (only about 18 inches), hollow like the carbon fiber rod, and perhaps because it was much lighter then his.
I do think it is important though being able to stick the endpin into the floor. Granted some places more then others. One concert hall I play in they have boxes for each player, similar to that a cello soloist might use, even has a bass bar in the box right about where you would put your end pin. These boxes make a huge difference especially when playing on the extension. |
![]() Quote:
![]() The one we used was a bit of an odd ball. I think it came from Bob's house of bass. I remember it being hollow because we were so worried about crushing it with his thumbscrew, my current aluminum endpin though is hollow.
I am about to try a solid CF rod on my bass. Found just finding a piece of 10mm carbon fiber is much cheaper then something that is an endpin rod ![]() |
![]() Wondering as Ken asks what difference there may be between tilting the bass with a straight pin as compared to the Laborie angled one? Also with the new hardwood ones are they adjustable length? Could they be installed straight if one wanted to? Lots of questions as I have never tried an angled pin but interested in what its like and very interested in using a wooden one such as this either way. Also with the Laborie pin how does it work if one is sitting to play? I mostly stand out of choice myself but sometimes in orchestra work of course sitting may be the norm. drilling the block does seem a bit extreme especially in an old valuable instrument but if it works .......
![]() You are not just drilling the Block. You are putting a hole in the Rib as well!
On the restorations I have had recently, many of the Basses needed a new Block and these only had one hole in it. Out of 8 Basses opened up, 4 or 5 needed a new Block (I don't recall if the Gilkes was replaced or trimmed as it looks old but not as old as the neck block). I can't imagine how a Block will last with two holes being drilled. I have only seen a few Basses with a separate Tailwire Socket and separate Endpin so I can't say for sure if this weakens the Block over time but using either Endpin over time is double duty on the Block itself. |
![]() Quote:
It's all about the balance. When I tilt my bass back on its straight endpin, it falls to the left if I don't hold it with my left hand. With the angled hole, the bass more or less stays back without falling. It takes some practice to find the balance point but when you do, you find you don't have to hold the instrument up with your hand, freeing it up. When sitting, I don't know how critical the angled hole is as I can position the bass in a more open cello-like position with the normal endpin. You would probably need a shorter Laborie pin for sitting depending upon the height of the stool. |
![]() What are you guys playing that all of a sudden a regular endpin is not good enough 150 years after Dragonetti?
![]() Quote:
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
Thread Tools | |
Display Modes | |
