I recently purchased a used u5 and i am looking for feedback on the best way to maximize it's full potential.As an Eden user,Tim,you might be able to help on this one.Is there anyway to bypass the Eden 550 pre and go straight to the amp section?Right now i do not turn up the Eden pre past 9 o'clock because i do not want to risk damaging it.Also ,if anyone else has the knowledge feel free to school me.Thanks
1. Why would you want to bi-pass the Eden pre-amp? 2. What do you mean by "turning up the Eden pre past 9 o'clock"? I suspect you mean the Gain and/or Master being turned up past 9? You're not going to hurt the 550 unless you take the load below 2 Ohms.3. Can I assume you want to use the U5 as THE pre-amp and the 550 as the power source? If yes, the answer would be to run 'Out' of the U5 into the 'Effects Return' of the 550, thus, by-passing the 550's pre. Tim B.
Tim Bishop Last edited by Tim Bishop; 10-10-2007 at 07:47 PM. |
Tim Bishop |
. So, you came out of the U5 'Out' into the front Input of the 550? If your answer is yes, than that would not be what you want to do.Are you sure there are no issues with the U5, Eden or cable you are using? Also, double-check your 'Ground Lift' on the 550.Also, I'm still a bit puzzled. Why would you not just want to use the 550 with it's pre-amp and other great features? Another option if you want to use the U5 as your pre: Try going from your U5 'Out' to the 550 'Aux' In.
Tim Bishop Last edited by Tim Bishop; 10-11-2007 at 09:32 PM. |
.Thanks for the help sir.Much appreciated.Btw,wish i had the duckets to take that Smith off your hands.Great looking bass |
Did you try going out of the U5 into the 550 Aux In?
Tim Bishop |
I tried the aux with the same results.nothing but hum
Hmmm, sounds like a bad cable and/or ground issue somewhere in the loop.
How is the 550 on its own? Any noise using it only with your bass?
Tim Bishop |
The 550 by itself is fine.I'll try another cable to see if that makes a difference.I'll let you know how it turns out.
Hey Tim,as it turns out,an unshielded cable was the source of my frustration.Everything works fine now.Thanks for the help.
Tim Bishop |
