Old 10-11-2007, 02:08 AM
Cool Why?
Mendell, I have a couple of questions that quickly come to mind:
1. Why would you want to bi-pass the Eden pre-amp?
2. What do you mean by "turning up the Eden pre past 9 o'clock"? I suspect you mean the Gain and/or Master being turned up past 9? You're not going to hurt the 550 unless you take the load below 2 Ohms.
3. Can I assume you want to use the U5 as THE pre-amp and the 550 as the power source? If yes, the answer would be to run 'Out' of the U5 into the 'Effects Return' of the 550, thus, by-passing the 550's pre.
Tim B.
Originally Posted by Mendell Beckford View Post
Your assumption (#3) would be right Tim.I'll try that.Thanks for the advice.Oh,btw,i meant the gain at 9 o'clock.
Ok. Now I'm trying to understand why you would want to do this. Is there a specific reason why you would want to by-pass the 550 pre for the U5 pre?
