Old 10-11-2007, 05:56 PM
Cool ???
Ok. Now I'm trying to understand why you would want to do this. Is there a specific reason why you would want to by-pass the 550 pre for the U5 pre?
Originally Posted by Mendell Beckford View Post
Whenever i plug into the gain stage of the Eden coming from the Avalon,i get an incredible low frequency hum if i try to pass 9 o'clock with the Gain.I tried what you said last night(#3) and also got almost the same results,though not as severe as going through the gain stage.Clueless at this point
I'm sorry, I'm confused . So, you came out of the U5 'Out' into the front Input of the 550? If your answer is yes, than that would not be what you want to do.
Are you sure there are no issues with the U5, Eden or cable you are using? Also, double-check your 'Ground Lift' on the 550.
Also, I'm still a bit puzzled. Why would you not just want to use the 550 with it's pre-amp and other great features?
Another option if you want to use the U5 as your pre: Try going from your U5 'Out' to the 550 'Aux' In.
