Old 02-21-2011, 04:06 AM
This is a good thread - better than most discussion I've seen on the subject. But still, I feel obligated to note that there's still (like always) a lot of grey area and overlap on the issues of actual string tension, perceived string tension, string length (fingering/interval lengths), and instrument response ("tightness", "looseness"). Obviously all of these contribute to how easily an instrument plays, but they're radically different issues that may or may not influence one another or even have anything to do with a particular bass and whatever playability issues it might have.
I think we could add to the quality info here by trying to separate some of these different aspects of "playability" and clarify them - or maybe give them their own threads - if for no other reason than to not perpetuate some of the common fallacies that so often seem to involve the issue of "string tension".
Excess Camber is the biggest problem with string tension that I see. Pressing down the notes further to reach the fingerboard is no fun than if the board was mostly flat. I prefer a flat board, let the strings pull the neck a little, the camber/board leveled if not as perfect as desired and then raise the bridge height if you need more clearance to the board, not scoop the fingerboard.
Overlooking the fact that the shape of the fingerboard has no bearing on string tension, technically speaking, which makes my question a little off-topic for the thread, I'm not quite getting this - are you saying that with a new fingerboard you like to start with no camber (literally flat), and then evaluate it under tension and add minimal camber only as needed to get sufficient clearance - just sort of free-form? Rather than creating a particular "shaped" camber on the board from the start?
