Old 09-08-2009, 11:18 AM
...I am wondering why they can't use the regular Endpin socket rather than drilling a second hole in the Block for the tilted unit. Also, how is it different to use a bent Endpin or just tilt the Bass with a regular Endpin. ...
Are you referring to the Laborie? And are you suggesting that the through-hole in the socket could be angled? I have not only pondered this, but done it. The through-hole is always straight simply because it's way easier to manufacture a socket this way. Making it angled not only complicates production, but the amount of angle is limited by the bore and height of the bottom block, and the diameter of the socket. I made some extra wide sockets for my basses and drilled the holes at an angle, but was only able to achieve about 10°. I think a typical Laborie installation is 30° or more.
Still, I find that even the modestly angled pin was worth doing. Besides the effect on playability of moving the center of gravity rearwards (which I find quite positive), my reason for doing it was to reduce skating. I don't know why, but I cannot use a rubber tip when sitting. Unless I have my sharp point deeply embedded in the floor, or have a belt connecting my pin to my stool, I will chase the bass all the way up to the conductor before the first break. Having an angled pin greatly reduces this tendancy.
Also, you reduce the active length of the endpin, which is especially beneficial for tall players. Having 15" of pin sticking out in front of you is bad for several reasons, stress on the bottom block being a big one. Cellists have adopted the "angle" in large numbers. I think they know something. Since most bassists don't extend their endpins very far, it is a lesser issue for us, but I think not insignificant.
So far, the choices are to either bore a second hole (Laborie), schlepp some heavy hardware - which looks like it came from a suspension bridge - (Eggpin), or use a bent pin which destroys the collar/setscrew. I never tried to market my angled socket because I decided players wouldn't accept the fatness or reduced angle. I think angled pins are a good idea, but a good design has yet to be offered.
