Go Back   Ken's Corner (Bass Forums Sponsored By KSB) > Double Basses > This New Bass > Modern Eastern Europe
Old 08-17-2010, 10:11 AM
Eric Swanson's Avatar
It seems as if the largest difference between the sizing and proportions of the two basses is the depth of the ribs as they move up the bass and the bend location. The Hart's ribs seem to be closer to a consistent width, until they hit the "bend," my bass seems to taper more aggressively, starting at the bottom.
The Hart's bend looks higher up on the bass; just by eye, it would seem to have greater internal volume than my bass.
I think your measurements are that of an English Maggini type bass. Very similar to my Hart-Maggini in many areas measured.
Hungarian;---------------------------------------Hart;
Upper bouts are 20 ¾” wide.......................20 3/4"
Ribs are 8 1/4" at the bottom.....................7 7/8"
7 1/4" at the bend...................................tapering
5 3/8" at the neck heel.............................5 1/4"
Body length (to bottom of heel) is 44".........44 3/8" (Top to the tips)
Bottom bout is 26" wide............................26 1/8"
String length is 41 5/8".............................
41 3/4"
The Hungarian and Romanians like most all others copied the Italians. In this case, the English made several Maggini/d'Salo copies in the latter 18th and early-mid 19th centuries. My Hart is most likely a forgery of a Maggini or antiqued to look old for marketing when it was new. Your bass is a copy of the copies or something Italian that came from Maggini as well.
